Results 1 to 10 of 12
Thread: Media and Winamp problem.
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    On my RR installation, when I select a music to play it doesn't play. At startup winamp appears and, even if in RRconfig it's set "hide Winamp" it remain on top. Within RR if I "double click" on a song it will play...but within winamp!
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    tell winamp to not "always be on top"
    CTRL A
    I believe.
    •Micke
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    also, make sure you only have one winamp copy running and that RR runs it.. if more than one copy runs, you may be controlling the wrong one (thus the funcsions won't respond).
    Ride Runner RR's Myspace
    Mar 2005
    Florida
    I have the same problem. Winamp is not set to be Always on Top, and Winamp is not running when Road Runner is launched.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Mare sure also that (if using winamp 5) you must NOT use a modern skin -- Use a CLASSIC skin, or the hide option won't work.
    Mar 2005
    Florida
    I am using the latest winamp 5 with the Classic skin.
    Maybe I'll give an older version a try.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by stoodo
    Show me your RR.INI file, chances are you just don't have the correct winamp path OR have more than one winamp running...
    Mar 2005
    Florida
    Thanks for all the help!
    Attached is the ini file. (renamed .txt)
    Attached Files Attached Files
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You'r INI seems to be ok (as long as you have winamp.exe on c:\program files\winamp\) .. can you take a screen shot of the issue ? Also, you can try running winamp first (manually) then running RR to see if it works.. it should even if your winamp path is incorrect.
    Mar 2005
    Florida
    I uninstalled and reinstalled winamp and the music plays just fine now. Weird.
    When I open Road Runner, Winamp opens and stays in the Taskbar.
    Should it do that or should it just open as a process?
  1. WinAmp visualizations in Windows Media Player (almost working)
    By NoPistonPC in forum Software & Software Development
    Last Post: 08-21-2007, 06:11 AM
  2. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 01:38 PM
  3. Media Engine start Problem
    By eddy in forum Media Engine
    Last Post: 05-31-2004, 11:32 PM
  4. OK, can I use Winamp 5 with Media engine.
    By Skraggy_uk in forum Media Engine
    Last Post: 05-20-2004, 05:33 AM
  5. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 01:39 PM
