Results 1 to 10 of 17
Thread: Mouse don't hide after hibernation
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    New problem
    Even if I select "Mouse Hide" option, after my PC wake up from the hibernation the mouse is still visible... Any suggestions?
    Thanks to everyone, as usual
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ummm... I have to check this out.. never had a problem with it, but I guess I can add extra code to make sure this will not happen..
    Ride Runner RR's Myspace
    Jan 2005
    Milan, Italy
    In fact, this is probably a problem of my PC since I had this problem even when I used MediaCar... However, it would be good if you could add a code to correct this
    Thanks a lot!!!
    Variable Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    Yeah I have this problem also, the mouse appears again after I come back from hibernation. I would greatly appreciate it if you could add some code to fix it
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Jan 2005
    Milan, Italy
    Perfect!!
    This one works perfectly!!!
    Thanks a lot!!!
    Another little question: using map monkey embedded in RR, I have to "auto hide" windows start bar, otherwise it will pop up occasionally.There's a way to fix this?
    Thanks again
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by garo
    Perfect!!
    Thanks a lot!!!
    Thanks again
    You should NOT use the auto hide option in the taskbar.. you should instead, disable the "keep taskbar on top" option.
    Jan 2005
    Milan, Italy
    Thanks a lot, you're right!!! I'm so dumb that I just didn't see that option
    Mar 2004
    Stockholm, Sweden
    Guino, can't you implement an option to hide the taskbar completely when RR is active, i can't help you with VB-code (and you probably know this already) but the Delphi code to do this is:
    TaskBarHandle := FindWindow('Shell_TrayWnd',Nil);
    ShowWindow(TaskBarHandle, SW_HIDE);
    Then SW_SHOW to show taskbar again...
    Just my humble opinion...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Passe
    Yeah, thought about that... but some people WANT the taskbar there.. so it'd have to be an option.. and when ON, if the program crashes or you have to kill it for whatever reason, you'd not get the taskbar back!
  1. Mouse pointer returns after Hibernation
    By tmar89 in forum Media Engine
    Last Post: 12-08-2005, 01:45 AM
  2. hide mouse??? and Hibernation Problem
    By cdevelasco in forum MM Bugs
    Last Post: 02-24-2005, 12:55 PM
  3. hide mouse in copilot?
    By aoLhaTer in forum Software & Software Development
    Last Post: 09-20-2004, 07:49 PM
  4. hide mouse in milkdrop
    By fantomas in forum MediaCar
    Last Post: 09-18-2004, 01:45 PM
  5. Mouse and Hibernation
    By slboytoy in forum Media Engine
    Last Post: 04-28-2004, 04:49 PM
