Originally Posted by
kuo
has anyone else been having trouble with this? when i use the touchscreen with roadrunner, (v 2.20.05) when i try to press a button for the first time, the button highlights but does not press. then i press again and the button presses. If i use a mouse it works fine. My theory is this: seems like roadrunner does not press the button unless moused over first to activate the "On" image before activating the "Down" image for the button. since using a touchscreen, you "jump" from one button to the next, the first press only activates the "On" image, so you must then press again to activate the "Down" image and then the button presses. What do you think guino?
