I got it to embed ok but if i touch anywhere in the app the windows task bar goes on top of RR.
Any ideas why that would happen?
Printable View
You have two options:Quote:
Originally Posted by WebDog
1-Run RRConfig and set "Hide:... Taskbar"
2-Right Click on the taskbar, go into properties. Then make sure that "Keep Taskbar on top" and "Auto-Hide taskbar" are BOTH OFF.
il try opt#1 tomarrow.
I had this problem. I didn't use the 'hide taskbar' because it seems a touch slow to 'hide' the taskbar. I simply moved my taskbar to the side and made it as small as possible. I had this same problem with MediaCar and moved the taskbar to the top and didn't have the problem anymore.
