Results 1 to 3 of 3
Thread: Fresh install uses 100% system resources
    Feb 2004
    Hi all. Just switching over from MediaCar due to some recomendations and I seem to be having a bit of trouble.
    As soon as I start RR it goes right to 100% utilization and locks up solid.
    I used the very latest InstallShield version just an hour ago and same issue. I uninstalled WinAmp pro and am now using the Winamp from Mediacar's directory with same result.
    It's a completely new OS load of Windows XP Pro SP2 running on an Epia M10000 with 256MB, 250GB HD, XMPCR(USB) connected to a USB SB Audigy 2 NX via optical digital cable, Griffen Powermate Volume control, Linksys USB wireless ethernet, Liliput 7" touchscreen & a 303 GPS mouse.
    Any ideas?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try going in RRConfig and setting up a different skin -- see if that works, the Brushmetal skin has flash objects and you might be running into trouble there.. in which case you'd need to updat the macromedia flash of the machine.. There's a full skin (Alpine) on my site if you want to "try" and see if that one works.. if it does. you probably just need to run Internet Explorer (Not any other browser please) and update the flash/shockwave players from macromedia's site..
    IF the above doesn't work, please post your RR.INI file so I can look at it. Chances are there's just a bad setting..
    Ride Runner RR's Myspace
    Feb 2004
    Updating flash did the trick.
    Thanks!!!!!
    BTW, now that I can use it, it's a wonderfull interface! Thanks for taking the time to put this together!
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 03:41 PM
  2. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 05:17 PM
  3. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 03:03 PM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
