Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Trouble going back from TV to Main Menu
  1. #11
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    I can't wait to try the winamp tv plugin with the Avermedia PCMCIA TVcard I've just ordered. Check out http://www.avermedia.com/cgi-bin/pro...lus.asp?show=2
    It may well be the ideal tvcard for Epia MII-owners with no room for a PCI card, like myself.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  2. #12
    Oct 2004
    Madrid, Spain
    Quote Originally Posted by guino
    Redownload version 3-8-05, the display format of temperature is fixed (now).
    Ok. Guino, it is fixed.
    The temperature format is now perfect.
    Thanks a lot.
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by GizmoQ
    Guino, how do I turn this bug back on? This is just the functionality I'm trying to achieve for thr radio, video, DVD and TV.
    If you use External DVD, you can do that by not using the 'close' button on the DVD screen, you should stop audio playback first though. For TV, I still have to do some work on it because right now even if you go into the Mixer it will stop the TV and play music, then restore the TV when going back to it. This is a little more complex than people think simply because of the "go anywhere from anywhere navigational structure".
    Ride Runner RR's Myspace
  4. #14
    Jan 2005
    Quote Originally Posted by mox
    I'm considering buying the same card (2nd generation TV card WITH FM RADIO!!!) for my MII12000 mobo. Would welcome your review or others' reviews on this product including how good the FM radio is.
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by togaf
    I'm hoping that this card will work as FM with Radiator either with the Avermedia drivers or the WDM FM driver.. I do not see it listed under radiator's compatibility list (not explicitly).. I'm sure the TV part works though..
  1. Replies: 8
    Last Post: 01-09-2005, 03:08 PM
  2. Add Applications - Main Menu
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 06:33 PM
  3. Tiny Music Embedded
    By Ashlawn Kemling in forum Software & Software Development
    Last Post: 05-31-2004, 06:49 AM
  4. 7" screen, which mobo/gfx to buy for 16:9 TV out?
    By Vittel in forum LCD/Display
    Last Post: 08-08-2003, 01:15 PM
  5. Epia 9000 Problem w/ TV Out
    By blazinlow in forum General Hardware Discussion
    Last Post: 03-05-2003, 12:15 PM
