Results 1 to 4 of 4
Thread: main screen title blanked out ??
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I have the following visual bug in version 15/3/
    After setting the startup command in the setup program to read
    gps||main
    Roadrunner loads the gps screen and then goes back to the main screen.
    The title and the date on the top of the main screen are blanked out. Also anything that uses labels such as "status" is not shown also. Now if you enter another screen (music...) and then return to the main screen then everything is OK.
    Everything is also OK if the startup command read "gps||main||main".
    It looks to me that this is some sort of refresh bug.
    P.S. I redownloaded the mini fix as mentioned in another thread but still nothing.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    sorry, you probably got it in the first 30 mins of the release.. I fixed it right away, so if you re-download, chances are it will work now..
    Ride Runner RR's Myspace
    Dec 2003
    Greece
    Quote Originally Posted by guino
    I did redownload but the problem is still there. Any ideas ?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    not really.. I guess I'll double check the code... there was a little bug that I fixed, but then two other people that had it, said it's fixed.. (i saw it too) so if you say your're still having issues after redownloading just now, I don't know ... As a note -- I don't believe I updated the source code package with this fix.
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  2. task switching? touch screen only
    By chuckctv in forum Software & Software Development
    Last Post: 09-04-2004, 10:50 PM
  3. Common theme in LCD screens..
    By spectrumzz in forum LCD/Display
    Last Post: 10-28-2003, 04:37 PM
  4. Replies: 4
    Last Post: 04-16-2003, 09:00 PM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
