Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Problem with Radiator: can you help me ?
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by pgiordano
    Yes, the Directshow driver is better. I suppose that it calls the hauppage functions.
    BMVEE, do you have the same problem from me if you enter a frequency like 95,25 ? Does the radio begin to scan up or scan down ?
    I have to add preventions against entering a BROKEN frequency such as the one you've showed.. You should NEVER enter a frequency with more than ONE decimal point.. Communication standards (in the U.S.) only allow for frequencies ending in .1, .3, .5, .7 and .9 -- if you wish to allow all frequencies, go in RRConfig and check the "Allow all frequencies) in the Radio Section. This should allow you to enter any frequency (even broken ones) but RR will always use the fine tune step setup in Radiator. This option should also solve your issue with the software seeking "forever".
    Ride Runner RR's Myspace
  2. #22
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have downloaded your patch and it works !! Guino, you're the best !
    But i have seen some strange things after that :
    When i enter manually the frequency 100, the frequency becomes 99,90
    When i enter the frequency with format XXX,XX or XX,XX, the radio begins to scan down ! and it is not possible to stop it !
    An other question, what is exactly the function of these buttons (see screenshot)
    Thanks a lot guy
    Read my previous post about the change of frequencies...
    The buttons are: Local Mode and Preset Number...
    Local Mode lets you use the Preset list without messing your home presets -- if you travel for instance, set local mode on, then do a "scan local presets", it will add the new presets and when you press it again (returning home) your old presets will come up untouched. You can scan/edit your presets as much as you want without screwing your home presets while in local mode.
    Preset Number simple lets you type in the number of a preset you wish to tune to.. say like 10 would jump to preset number 10 in your preset list.
  3. #23
    Mar 2005
    Thank you for your answers, Guino. Congratulation for your support and your work !
  4. #24
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    No... It's working fine for me...
  5. #25
    Mar 2005
    after change enable allow all frequencies in RR I can tune up only. both buttons freq - and freq + working only for seek up. when I disable "allow all frequencies" everything is ok with "freq -" button I can seek down also. whats is wrong?
    I also has problem with "scan" mode - after start scaning I can only see at changing freq but radio dont stop on found station but still scan. why?
    sorry for my english however I hope that everybody can understand me
  6. #26
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by albert
    Does the scan function work in Radiator ? If not, then it's a setting issue.
    Download this for your "Freq-" issue: http://guino.home.insightbb.com/rr.exe (save over you current RR folder)
  7. #27
    Mar 2005
    hi Guino
    thx a lot for your help freq- working ok already. however I still cant to using scan function. my card is hauppauge WinTV USB. scan function doesnt work with radiator also. what is incorrect in settings?
    how to remove popup windows with radiator when under RR I start radio function? I checking all possibilties in radiator preferences but without any results - popup with radiator is show for 1-2 seconds....
    Ali
  8. #28
    guino's Avatar
    Nov 2004
    Toronto, Canada
    hi Guino
    Ali
    You should disable the spalash screen in radiator settings, also, run Radiator alone (outside RR) and try the seek functions, if they don't work right, you should probably try a different Radiator plugin to control it.
  9. #29
    Mar 2005
    Quote Originally Posted by guino
    where can I disable splash screen? I cant find this option.
    I using for my winTV USB tuner 8x8wdmfm.dll driver and DM FM Radio.DLL also - rest doesnt work with my tuner - who have hauppage winTV USB FM tuner? which drivers working with my tuner and working with seek function?
  10. #30
    guino's Avatar
    Nov 2004
    Toronto, Canada
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 08:58 PM
  3. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 08:27 PM
  4. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 01:38 PM
  5. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 11:09 AM
