which radio card are you using?
When i push the radio button, Radiator is beginning to launch but the frequency in RR is equal to the value 0,00. The frequency doesn't change when i push scan, surf or change the frequency manually. These buttons have a null effect on Radiator which is in the taskbar. The playlist is empty too.
I believe that it is a configuration problem. i tried all the local variables in RR configuration. I suppose that the radiator path is well configured because radiator launch when i push radio button in RR.
In Radiator the option "Minimize in system tray" is enabled and "Scroll text on taskbar icon" is disabled.
My system is windows xp french version.
Can you help me, please !!
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
I use a Hauppage WinTV GO FM. Radiator works fine with this card.
well i had same problem with my setup. it was a problem of the earlier versions of Road Runner exe an it should be fixed in the actual release:
- be sure Radiator works when launched alone;
- be sure u installed the last binaries;
- don't create any presets in Radiator, u'll be able to do this inside RR;
- try disable internationalisation in config;
if u check these things, Radiator should run perfectly.
cheers.
I made all you said and no change, AHRRG !!!!!!!!!!
I have installed the Road Runner 03-19-05 Binary.
The skins is BrushedMetal downloaded on Guino web site
My version Radiator version is 1.8.0.7 (2003-8-25)
No presets in Radiator, i tried with option "disable internationalisation" enabled and disabled, it is the same thing.
Have you an other idea ?
Same Prob.. Same card... working on it... I'll let you know what I can find... Guino???? thoughts????Originally Posted by pgiordano
Each of you, please make me a screen shot of Radiator working ALONE (outside RR) -- Make sure it INCLUDES THE TASKBAR... Also, on the same screen shot (if possible) open the calculator and type in 1 / 2 = (One divided by two and hit 'equal') with this I intend to obtain an important regional setting of your system. After that I'll be able to diagnose the problem better.. the 3-19 release should have what's needed to work with radiator in any system, but if the two of you are having issues, I have to see about it.. may be you just don't have radiator setup right -- you MUST (I repeat MUST) disable the "scroll title" option from Radiator.
Ride Runner RR's Myspace
Here is my screenshot. I confirm that the "scroll title" option is disabled. Thank you Guino for your work !
Please try this "update" (just unzip onto your RR's install location):
http://rmc.pimpedwheels.com/rr.exe
Let me know,
Guino.
I disabled scrolling as well as removed the welcome message (before the update... sorry, my fault for not paying attention), solved the hunting problem for me. I can't manually tune any stations, and when I hit "scan", radiator seems to start to scan endlessly no matter what I do. In fact, once I have exited RR, I have to end the Radiator task.Originally Posted by guino
BTW I tried the update... no change
Here is the Screen Shot
