Results 1 to 9 of 9
Thread: Audio at start of a track is 'choppy'.
    Hard to describe but I'm hearing it a lot - as a new track starts playing the audio is slightly glitchy and distorted. Not hugely so but noticable. Will have to confirm if I can repro this outside RR (e.g. in winamp or media player by themselves).
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This might be as simple as checking your mixer settings... CD Drives and Analog input devices can throw a lot of noise into the audio output if you leave them unmuted. The other thing is you should check your winamp output plugin and maybe trying a different one..
    Ride Runner RR's Myspace
    All my music is variable bitrate wma files. So it's not hardware. Could easily be the winamp plugin.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    there are different winamp plugins for most file formats... may be you should try a different one or try changing the settings of your current one.. Buffers, timing etc..
    Tried the Windows Media Center shell and it doesn't have the problem (it uses windows media player for playback). I haven't experimented with tweaking or replacing my version of winamp yet.
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    I have some choppy issues in Winamp as well. But the big thing for me is that WMP plays my mp3 through my Extigy as 5.1, but I can't get Winamp to play in anything but just the fronts. I have two output plugins: Directsound and WaveOut. I've played with both of them but get the same results. Anyone have Winamp doing 5.1 and/or setup with an Extigy?
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by wysocki
    I have winamp playing 5.1 all the time.. but my decoder does all the job.. I just have a digital output out of my MB into my decoder and everything comes out surround. You should just probably look into a digital output plugin for Winamp, or mess with the settings they have to try to get it to work.
    Mar 2004
    Los Angeles Area
    Went to the Winamp forum and found the answer there. Turns out it needed DirectSound output WITH hardware accelleration for the Extigy. Thanks!
    http://forums.winamp.com/showthread.php?threadid=66049
    Newbie maestro83's Avatar
    Aug 2005
    Alessandria
    hello all I wanted to ask to you if someone has a solution in order to resolve my problem why I do not feel sound from the subwoofer when I put in play a mp3 with winamp.
    for it appeal to you help me
    excused my English
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  3. TRACK NUMBERS_can't get the track numbers to display properly
    By fly_dutchie in forum FP Bug Reports
    Last Post: 11-06-2004, 02:44 AM
  4. mp3 names in Mediacar to include track nr?
    By fly_dutchie in forum MediaCar
    Last Post: 07-15-2004, 01:53 AM
  5. MPXPlay - Stutter Start!
    By DaBretty in forum Software & Software Development
    Last Post: 07-24-2000, 12:06 AM
