Results 1 to 10 of 11
Thread: Road runner almost but not quite dpi unresponsive.
    I've switched my PC to high dpi via the display control panel to make normal windows more touch screen friendly. This had virtually no effect on RR which is desirable since it's skinned appropriately for a small screen already. However, the temperature labels which didn't overlap before do now. I'd very much prefer the label font size was not affected by dpi settings.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That's something that WINDOWS changes -- the fonts in all applications get changed.. The only solution for it that I know is to edit your .skin files to make room for the extra size of the text. Even if I drew the text by hand, it would still show bigger because windows takes over the size of the fonts..
    Ride Runner RR's Myspace
    You should be able to prevent. that. It's easy in C++. (Usually the bug is that it doesn't change automatically). I'll add it to my list of things I'll investigate when I can make some time to look at the VB code.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you find a way to make a label unaffected by the DPI setting, I'm in for it.. because that can be a pain in the neck sometimes... All I do right now is set the font's name, size , color and tell it what to display.
    (Off the top of my head) Try specifying a negative size.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    well.. in VB that gives me an error..
    Mar 2005
    A posible solution is to make the fonts out of a .bmp or graphic file, this way the size will not be afected by the changes made in windows
    Mar 2005
    maybe the skin could have it's own font asociated in the graphic files, it would be cool but it requires a big effort not just a parameter toggle.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well that's what winamp does.. everything graphical (images).. it's not hard to make a user control to do that, but then just because it's not a standard font, a bunch of little issues start to come up, speed, redrawing, transparent background support etc etc..
    Raw Wave
    Jun 2004
    On the beach
    Sounds like a lot of effort to me just for changing a few .skin entries, everyone will be different, and anyway you only need to change the .skin file once.
  1. Road Runner Installation Program
    By bry21317 in forum Road Runner
    Last Post: 01-29-2008, 09:22 PM
  2. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 12:40 PM
  3. Replies: 0
    Last Post: 03-14-2005, 01:48 AM
  4. Why have you switched to Road Runner?
    By more mods in forum Road Runner
    Last Post: 02-21-2005, 02:48 PM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 11:16 AM
