cool, I hope you've got the answerOriginally Posted by rustyboxx
Yeah, I had that problem too. I got it after I changed a setting in RR config. It bugged the life out of me for a couple of days. Everything went back to normal after I changed the setting back in RR config. I can't remember off hand which one it was but I'll check it out when I get in the car next and let you know.Originally Posted by Tsleon
Only true postwhores remember everything they post
REP CLUB IS DEAD
LONG LIVE REP CLUB
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAMold carPC
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
Ok, I think the problem occurred when I had the 'Reduce Sound Volume to' option checked in RR config. I seem to remember unchecking it and the problem went away. I recently updated to Guino's latest release and have just tried to re-create the problem but it didn't happen. So, either that issue has been fixed in the latest release or I've remembered it all wrongOriginally Posted by ITL
REP CLUB IS DEAD
LONG LIVE REP CLUB
i had the same problem. soundcard driver was not the case.
i unchecked "reduce volume ??%" checkbox
O thank god others had this too.. I thought it was only me...
so this "reduce volume" checkbox is in the RR config?
yes it is
add this line to your RR.ini and it should fix it.
exitmute=false
beer replenishment fund
mp3car live search
I'm having a strange issue but its not rr causing the problem,it seems to be windows causing it.
If i shut down from RR all is ok on restart,if i just turn off the key and let my M2 turn it all off when i resume i have sound from windows but Winamp volume slider is at 0 (winamp main window volume slider),ie no sound from RR.
Is there anything i can do to combat this?
You can save/restore presets for those weird issues.. this is the kind of stuff that happens normally if windows starts closing applications before RR has a chance to propperly close them..
Change on your "SHUTDOWN" button to this:
"!PRESET;STARTVOL||SHUTDOWN"
and this in RRConfig's start command:
"PRESET;STARTVOL"
It should save and restore the volumes when shutting down/starting RR. You can add that bit in front of the shutdown command to the exit/quit/restart commands as well if you'd like.
Ride Runner RR's Myspace
