Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: Audio muted problem
  1. #21
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have a strange one, this is on the desktop PC, don't know it if does it on the carPC but then it wouldn't really matter.
    When I exit RR, it reduces the wav volume to zero. (doesn't mute the soundcard, just affects the wav volume). I have tried mapping to Master, wav and all. All with the same result, this has only happened with recent releases and my soundcard drivers have not changed. Also tried the exitmute=false line in rr.ini but that didn't work either.
  2. #22
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I changed the mechanism on shutdown to mute winamp and restore its volume when exiting, if the output plugin you're using is "linked" to the wave line, this could happen, though it is supposed to restore it before it closes winamp -- I would ask you to try a different output plugin (Winamp comes with 2 of them)
    Ride Runner RR's Myspace
  3. #23
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    tried adjusting all the plugins, but no dice.
    If I have the volume contyrol open and in view it doesn't do it.
    weird.
  4. #24
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the exit mute option was removed when I made that change, but I guess I'll put it back then (As a fallback for this kind of issues). I swear it works perfect in all of my machines.
  5. #25
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    I am having this problem aswell. When i reboot i have no audio RR, and i need to go open winamp and set the volume to 100% (the slider will be at zero every time)
    5th september 06 RR
    winamp 5.x
    The problem only appeared after updating from a RR release about from about a year ago. I have added exitmute=false but it had no effect.
    I am confident it is happening because i am doing a very nasty windows shutdown. I wrote my own shutdown app that uses a delphi forced shutdown command, and i dont think it waits for anything. I will try adding the presets as you have described guino and see how it goes.
  6. #26
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by soundoff View Post
    5th september 06 RR
    winamp 5.x
    It's not likely that it's because of your nasty shutdown (though that's not a good thing), because my WinAmp started doing the same thing with this release. Not sure what was causing it, but everytime RR started up, the WinAmp volume would be set at Zero. So I had to open WinAmp independently, slide the volume to 100 and then close it out. After than, when RR was opened, the volume was were it should be. It was really ****ing me off till I figured it out.
    It has something to do with the winamp plugin it seems, there is a volume option, return to previous level on close. so when RR was running WinAmp, WinAmp was thinking (for whatever reason) that the slider volume was at zero, so even if you raised it while RR was running, when you closed out RR and WinAmp was shut down, the volume slider was dropped back down to Zero.
    I'm using the latest binary and WinAmp 2.95
  7. #27
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    That maybe so but it was ok till a little while ago,whatever the reason for this change to RR and winamp,it needs changing back,right now.
    My power supply shuts everything down,there's nothinhg nasty about the procedure,but now i'm reduced to sitting in the car and shutting it all down manually so as to save face in front of people when it comes back on,its all a bit sad.
    please some1 restore winamp to its former self,stuff the workarounds.
  8. #28
    guino's Avatar
    Nov 2004
    Toronto, Canada
    get the latest beta and add: exitmute=false to RR.INI, then try it.
  9. #29
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    It may be a winamp lack... I've noticed that if it is stopped, a volume level change doesn't have effect in the windows mixer.
    So, the code below doesn't be able to restore the volume level when exiting from RR
    Code:
    'Close Winamp
    SendMessage hWndWinAMP, WM_COMMAND, WA_STOP, 0
    WinAMP_SetVolume WV <--- This doesn't work as expected
    Winamp_Close
    Now I don't know if this happens always or it's just with some sound cards, however I've found that the problem can be solved setting the option "Reset to original value on stop" in winamp.
    I hope this would be helpful.
  10. #30
    guino's Avatar
    Nov 2004
    Toronto, Canada
    nice finding Rob.
  1. Need help with audio install
    By Zebelkhan in forum Car Audio
    Last Post: 01-24-2005, 05:15 PM
  2. win2k and m10000 audio
    By prometheusg in forum General Hardware Discussion
    Last Post: 10-15-2004, 03:15 PM
  3. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  4. XMDirect Digital Audio Output ?
    Last Post: 10-11-2004, 09:10 PM
