Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 46
Thread: Audio muted problem
  1. #31
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    excellent find rob. will try it this evening
  2. #32
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    That worked sweet,thanks Robby.
  3. #33
    Nov 2005
    Midlands
    Actually,I was a bit hasty,it didn't work.
  4. #34
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    crap... I thought I posted my bit last night but apparently it didn't take.
    What I was trying to post last night was that.. Not to be a downer, but the "Reset to original volume" was already check on my setup in Winamp. What was happening was whenever RR started it, 'something' was dropping the Winamp slider to 0, so I would have to switch to Winamp, raise the slider to 100, switch back to RR and the audio would work. Problem is when I exited RR, the Winamp volume would go back to 0, I assume because it was thinking that was the 'original' volume. The only way I could get things to work right, was opening Winamp, with RR CLOSED (not running at all), raising the slider volume to 100 and then closing Winamp. After doing that a few times it finally 'stuck/took'. lol and has worked ok since then. Not really sure what was causing the Winamp volume to drop to 0. I have RR configured to ONLY work with the Master Volume and it seems the Winamp slider volume was dealing with the WAV Volume.
  5. #35
    Jul 2004
    AUSTRALIA
    After hacing a look at Rob's suggestion, i eralised i was using directsound output instead of the old wavout dll
    I switched over, and checked the suggested option and it seems to have worked. I have only had 2 reboots since then, but they have both worked fine.
    fingers crossed
  6. #36
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @Griff1: Did you try the latest beta with the Exitmute option ?
    Ride Runner RR's Myspace
  7. #37
    Nov 2005
    Midlands
    Quote Originally Posted by guino View Post
    i'll try it today Guino.
  8. #38
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    When the above solution was posted I was tempted to say I'd already tried that and it hadn't worked, but by then the new beta was available, which does work. Thanks G.
    although I will add I never had an issue with the volume within RR, it was just the muting on exit that I had. (unless I had the volume control open and maximised)
  9. #39
    Nov 2005
    Midlands
    Do i need to change the RoadRunner.exe to RR.exe or doesn't it matter,i'm not using the Google bit.
  10. #40
    Jul 2004
    AUSTRALIA
    mines started doing it again dammit!
    Will try the beta exe
  1. Need help with audio install
    By Zebelkhan in forum Car Audio
    Last Post: 01-24-2005, 05:15 PM
  2. win2k and m10000 audio
    By prometheusg in forum General Hardware Discussion
    Last Post: 10-15-2004, 03:15 PM
  3. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
  4. XMDirect Digital Audio Output ?
    Last Post: 10-11-2004, 09:10 PM
