Results 1 to 3 of 3
Thread: Little trouble using NaviPC embedded
    I use navipc as gps navigation software and there is only one problem, runing it embedded. As shown in the picture attached (shot take at higher screen resolution to see the problem) pressing F4 navipc creates and pop up a new window that let you choose the DVD map country to use for searching places to add to the route, but the windows goes immediately on the backgroud and it disappear! Is there a workaround to solve this? I used the same in Mediacar and it works.
    paperinics
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This happens only with badly written applications that don't associate the windows of the application correctly.. I do intend to make some sort of "fix" for this..
    Ride Runner RR's Myspace
    Thanks guino, I know that probably the application is not written in the better way.
    In fact that navipc window is the only one that can be placed in the backgroud, also running in standalone, outside rr, but normally if you keep the focus on it, you can get the window to stay on the foregroud until you make your choice.
    Thanks for your work, if in the next versions you'll find something to "fix" this, it will be for sure very useful, form many other applications that can present similar problems.
    paperinics
  1. CoPilot Live 8 Embedded
    By chuckster in forum Centrafuse
    Last Post: 11-10-2005, 12:24 PM
  2. Screen size of IGuidance Embedded in FP
    By PDiddy in forum FrodoPlayer
    Last Post: 02-11-2005, 07:07 PM
  3. Extracting Embedded Web Video
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 02-10-2005, 03:27 AM
  4. Gapless playback between MP3's in WMP embedded in VB6?
    By CRCinAU in forum Software & Software Development
    Last Post: 05-23-2004, 03:40 AM
  5. Newbie embedded MP3++ system
    By Steinola in forum Newbie
    Last Post: 05-16-2004, 09:49 AM
