Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: winamp plays when in video mode
  1. #11
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    alright. the video works, but now it seems like roadrunner has highjacked my audio. I am using an M-audio Delta 44 and when I start RoadRunner it says the volume is all the way down, when I turn it up, it works fine. my WMP9 is all the way up, not muted, and won't play audio, and neither will winamp when it's not opened through RoadRunner. I went into the sound properties for the audio interface, and it is all the way up, but it still doesn't work. what can i do :O
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ummm... I really haven't messed with audio here... My first guess would be to make sure there's nothing muted in the mixer. then my next guess would be to check if you're running the same winamp in and out of RR, and verify they're using the correct output devices... The last thing I'd do is double check you haven't accidently set RR to mute any audio lines in RRConfig.. this is pretty weird... I never head of it working in RR and not in Windows (I have heard the opposite).
    Ride Runner RR's Myspace
  3. #13
    Feb 2005
    Austin, Texas
    I changed the "map master volume to control line": to "all lines" from "master volume" and everything works now. it's an audio interface more than just a sound card, so that makes it much different to work with.
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    glad you worked it out..
  5. #15
    Feb 2005
    Austin, Texas
    thank you for spending so much time on this project. Do you know anything about programming a directX plugin for a program like sound forge? :P
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    umm.. not really.. I know more of OpenGL than DirectX... but even there it's been awhile.. most of the stuff I do is hardware-software integration, database etc...
  1. Replies: 21
    Last Post: 02-10-2005, 11:39 PM
  2. Replies: 6
    Last Post: 01-28-2005, 08:32 PM
  3. VB6 help: Kill Winamp VIS/Video
    By MatrixPC in forum Software & Software Development
    Last Post: 06-23-2004, 11:56 AM
  4. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 01:16 PM
  5. Divx video playback
    By mindtool in forum MediaCar
    Last Post: 12-08-2003, 05:19 PM
