Results 1 to 6 of 6
Thread: Radio problem
    FLAC mauri's Avatar
    Jan 2004
    Radio problem
    Tested in my car the 30/03 update.
    all ok, only one problem with the Radio module.
    Is ok all functions, but the number of freq. receiver don't displayed ,only the name and position of preset.
    Displayed ok the freq in all other module by RR
    Only in the Radio module the problem.
    Check, the RR.ini its ok.
    EDIT:the GPS Com port setting and hother path to the GPS add functions in Config utility is only if I use Mappoint (GPS Com port,location,etc...)?
    The mute volume to message work with MM?
    Mauri
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I haven't changed anything with the Radio... I'm assuming you use Radiator.. screenshot please (including taskbar AND Radiator) ?
    The volume mute works for MapPoint and the SAY command in RR ONLY. You can still use MM's option to mute volume..
    Ride Runner RR's Myspace
    FLAC mauri's Avatar
    Jan 2004
    Ok Guino,fixed!
    In Radio_player.skin the label is write " FREQUENCY"
    Change with " FREQUENCE" and all ok.
    Mauri
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ohh... it surprises me you had not tired a different skin before anything..
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    possibly similar problem. Mine shows any freq >107.00 (using radiator) as 0.00FM (even though radiator will show proper freq.) This also causes problems with presets. I can't change to/from it.
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Every time I restart RR I lose all my radio presets, using a Silabs. Tried it in DigitalFX2 and FreedomUltimate
    Anyone got any ideas?
  1. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 02:58 PM
  2. Radio volume doesnt mute
    By miztahsparklez in forum FrodoPlayer
    Last Post: 03-06-2005, 05:45 AM
  3. I *think* I have isolated the problem. help?
    By mpfjr in forum General Hardware Discussion
    Last Post: 02-24-2005, 05:53 PM
  4. DLink USB Radio: Install Problem or Bug?
    By millec in forum ME Archive
    Last Post: 06-01-2003, 01:37 AM
  5. FM radio capability without head unit.....????
    By bankingdom in forum General Hardware Discussion
    Last Post: 05-14-2003, 12:44 PM
