I had to change a few things with the power off/reboot of new version.. I may have a clue of the problem..
Resume on shutdown doesn't work in newest version anymore and RR doesn't always remember current playing song. It starts first song on the playlist. Deleting resume.ini and rr.ini didn't help![]()
Ride Runner RR's Myspace
RADIO PLAYLIST ISSUE, SCREEN REDRAW AND SHUTDOWN RESUME PATCH
download at: http://guino.home.insightbb.com/rr.exe
I am in the middle of other things so no release yet...
Thanks Guino! I test patch at once.
Patch didn't help, newest version has still same bug![]()
umm.. I'll double check, but I'm pretty sure it was working.. if you use an automated option to shutdown instead of using RR's skin (Opus etc), then you'll have to add this to your RR.INI:
exitmute=false
Then it will never try to mute on exit.. the mute is so that when exiting the software from the TV, Radio or Video screens won't resume the music playing on winamp for a fraction of a second while shutting down..
Problem isn't mute this time. Problem is that RR doesn't start automatically playing song. It goes first song on the playlist and doesn't start Play, when I start PC and RR.
I had never this problem earlier versions.Two newest versions have this bug, or my computer is messed up![]()
I'm using girder and RR's own shutdown command.
Ok, I have an idea of what it may be..
I was having a similar problem -- if I suspend (triggered by OPUS) while in XM radio mode, when resuming, it will still show the XM screen but start playing whatever is in the winamp playlistI tried to set "line in plugin" but that did not help. I tried to download the rr.exe in your link above but got nothing... I downloaded http://rmc.pimpedwheels.com/rr.exe -- hope that is the current version? Will try it in a minute.
Edit:
Well, if that was the right version, it didn't work, though a bug with drawing seems to be fixed... Anyway the problem is this:
When I suspend while listening to an XM station, you can see RR briefly flash to the MP3 playlist screen then the computer suspends. When it comes back up, RR is still on the XM screen but no audio is playing. When you double click on the items in the list (the XM stations) one of the MP3's in the winamp playlist begins playing instead. If you hit the back button to return to the main menu, then go into Music, the correct mp3 will indicate that it is playing.
I suspect the behavior would be the same w/ hibernate as the event name is the same...
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46 ///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
I have tested XM with HIBERNATE, never tested it with stand-by.. If you're having the issue above than its likely that the event is NOT being treated as the same in Windows.. I'll have to look at it..
