Results 1 to 10 of 14
Thread: DVD play's choppy
    Variable Bitrate Erwin's Avatar
    Mar 2005
    DVD play's choppy
    Hello,
    I installed roadrunner on my Epia M10000 (1GHz) 512MB RAM. My problem is that all DVD movies play choppy. When I use an external application (Powe DVD) it doesn't. I would like to use the build in DVD player because it looks better. How can I solve this 'chopping' problem?
    I also can't get a visualisation on the screen. It only appears in winamp and doesn't appear in RR. How can I solve this problem?
    Raw Wave
    Jun 2004
    On the beach
    For the Vis problem check the RR FAQ Forum - it explains how to fix it.
    Mar 2005
    Quote Originally Posted by UK_MP3Car
    I'm sorry but I can't find it in the faq.
    Raw Wave
    Jun 2004
    On the beach
    I just did a quick search for RR Vis and came up with an answer below:
    How to get VIS to show...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    DVDs... well.. honestly, depending on the DVD even on my 2.2Ghz P4 it gets choppy.. It's got to do with Media Player Classic and hardware acceleration... You should play around with MPC OUTSIDE RR, get it to where it runs best in full screen, then copy the mplayerc.ini file as mpc.ini in RR's folder -- this is so RR uses those settings. It should virtually be the same when playing DVDs inside or Outside RR. You may want to try FrodoDVD to compare speeds...
    Ride Runner RR's Myspace
    Mar 2005
    I tried Frodo, and there I don't have this problem. I think frodo uses Power DVD to play DVD-movies. Can I use Power DVD in RR without using an external program?
    Mar 2005
    Thank you!!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Erwin
    I thought Frodo used FrodoDVD or something built-in based on the same thing.. FrodoDVD can be used within RR as an external DVD player. Currentely RR only supports Media Player Classic for DVDs.
    Mar 2005
    Quote Originally Posted by guino
    What version of Media player classic do you reccommend? Maybe I use the wrong version...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You download it from source fourge... and it should match your OS type.. I believe the version I use is 6.4.8.3, but newer versions should only be better..
  1. Replies: 7
    Last Post: 04-05-2005, 12:37 AM
  2. DVD_ dvd playback is choppy
    By Squid in forum FP Bug Reports
    Last Post: 12-01-2004, 11:29 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  4. DVD Rips?
    By EBFoxbat in forum Newbie
    Last Post: 07-20-2004, 06:09 AM
  5. DVD is choppy, Divx is smooth ????
    By Raas in forum General Hardware Discussion
    Last Post: 11-25-2001, 01:53 PM
