Results 1 to 3 of 3
Thread: radio preset under 87.9
    Apr 2005
    hello, my happauge WinTV usb FM works well with radiator and RR.
    But when i add a preset with a frequence between 87.0 and 87.8, it doesn't jump to it when i click on it with RR.
    It works fine with radiator...
    What could be the problem. It's a bit annoying cause my favorite radio is on 87.8... Bad luck :-(
    Moreover the surf function is fixed to 4s in radiator and works well but it when i use the surf function in RR it's about 10 seconds... Is it normal ?
    Thank you guino ;-)
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the surf in RR is set on RR.INI by this line:
    I'll extend the range of the radio so you can tune down to 86.9 .. There are no U.S. stations under 87.9 and as a matter of fact, none ending in even number either..
    Ride Runner RR's Myspace
    Apr 2005
    thank you very much guino !!!
    You're great :-)
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 02:58 PM
  3. TM-701L converted Lilliput causes radio interference
    By archimense in forum LCD/Display
    Last Post: 07-04-2004, 09:14 AM
  4. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 11:52 PM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 03:38 PM
