Results 1 to 10 of 13
Thread: radio:Bug release new 25/04
    FLAC mauri's Avatar
    Jan 2004
    Hi Guino,
    i have installed the new release 25/04
    Two problem in Radio module:
    I use the D-link and the two buttons of "TUNE" and "PRESET" with the new version they don't work anymore, impossible to use the keypad for these functions.
    With the old versions it was everything ok...
    Mauri
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll look it up.. may be a bug because of the Phoco code...
    Ride Runner RR's Myspace
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    I have a different bug.
    With via ac97 sound card it doesn't unmute mic line where I plugged d-link.
    Actually it doesn't unmute any of the line I can indicate as connected with d-link
    See my car and donate for spinning logos at www.ildena.it/carpc
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have seen that in some cards, the mute/umute doesn't work for some of the inputs.. I'm yet to find out why, but with the DLINK you don't have to mute the line as the driver mutes/unmutes the device as RR powers it on/off.
    Dec 2004
    Italy
    Quote Originally Posted by guino
    sincerely it seems as radio module has saomething problems...
    "tune" and "presets" don't work and I still have the line unmute problem...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    sorry about the preset/tune -- a bug was added when I added favorites support to XM.. (re)download the latest version and it should be fixed in it..
    Regarding your "unmute" problem.. you may just have one of those cards in which unmuting the line simply doesn't make the sound come direct to the speakers... in this case you MUST use the line in plugin... many built in sound cards are like that..
    Dec 2004
    Italy
    I open RR radio lookin at volume control panel... And I see that mic line isn't enabled... It's a peaty because I just finished the carputer restyling and now radio works great. :-(
    Dec 2004
    Italy
    I tried line-in plugin but I dont't know why (perhaps I'm not able to configure it or the problem of mic unmute has no solution) it doesn't works.
    Could you tell me a little more about line in plugin configuration...?
    Very, very, very good job with phoco.
    I found a little problem with skin redrawing...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, the UnMute/Mute thing has a limitation by design: You MUST have it MUTED before going into Radio because all it does is TOGGLE The mute state of the line... so you should have it mute FIRST (so going into radio toggles it to unmute, then leaving radio toggles it to mute again). Now, if you have one of those cards that the mute/mute doesn't work right, you should probably just leave it UNMUTED and set RRConfig to Disabled on the radio input line setting.
    All you have to do for the Line In plugin is check the box in front of it in RRConfig... assuming that you have installed the plugin, you should configure it to use your Mic In (Winamp plugin prefs). There's a wizard thingy in there to help. You just need to tell it the line input to use, the SampleRate, Number of Bits and channels..
    Dec 2004
    Italy
    I'm game-over!!!
    I'm not able to solve the problem. Mic line isn't unmnuted... and I don't understand how to set line in plugin...
    Am' I stupid...???
  1. Alpha Release: XMPC-CAR for XM
    By gork in forum Software & Software Development
    Last Post: 01-11-2006, 01:19 PM
  2. Release: PyCar-1.3.0.2
    By jbors in forum PyCar
    Last Post: 10-24-2005, 02:07 AM
  3. [SKIN]FPs "Bright Life" (input needed to complete)
    By yunusyu in forum FrodoPlayer
    Last Post: 06-25-2005, 03:59 PM
  4. [Release] GammaControl v.4
    By 0l33l in forum GammaControl
    Last Post: 11-10-2004, 06:32 PM
