Results 1 to 5 of 5
Thread: winamp
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    winamp
    when you remove the last track from the playlist, eg you have two in there, and lcick the little red line twice to clear them, i get a program error saying winamp.exe has created errors and will be closed,
    i know it works fine in winamp as i have tried it and its ok.
    edit: also, while on about audio, it doesnt look like the presets work
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by dan__wright
    I'll look into the remove issue, I do believe I tested that before.
    The radio presets DO work, you probably don't have your radio card setup right. in any case, there're lots of preset functions int there, so you'd have to explain what YOU mean by "presets don't work".
    Ride Runner RR's Myspace
    Apr 2005
    UK
    sorry, not radio presets, the eq presets, they dont change anything.
    Type-R Mini
    guino's Avatar
    Nov 2004
    Toronto, Canada
    uhh.... you have to press-and-hold the presets with the state you want to save, then you press it normally to load a previously saved preset. save a few presets with changed EQ settings then press the buttons and you'll see them loading.
    You can make them save/load just the windows mixer or just the winamp EQs (default is BOTH). Look at skin commands.txt to learn how to do that.
    Apr 2005
    UK
    ah ok sorry, im being a but dumb today, i thaught you selected it and set what you wanted, and when you go back it it loads them.
    Type-R Mini
  1. Winamp Plug-In Sets iPod Music Free
    By Gobby in forum General MP3Car Discussion
    Last Post: 08-12-2005, 01:31 PM
  2. EPIA video + Winamp standby problem
    By crisr in forum General Hardware Discussion
    Last Post: 08-25-2004, 07:16 PM
  3. Questions about MediaCar Winamp vs. External Winamp...
    By Urinemachine in forum MediaCar
    Last Post: 07-21-2004, 02:33 AM
  4. Winamp Problems
    By Axis_Inc636 in forum Software & Software Development
    Last Post: 05-12-2004, 12:16 PM
  5. WinAmp 3
    By Rob in forum Software & Software Development
    Last Post: 01-26-2002, 09:00 AM
