Results 1 to 9 of 9
Thread: RR wonīt respond after restart...
    Feb 2004
    Just installed the 2nd newest RR update and it worked great!...until i restarted the computer.
    Now the files wonīt show in the list, and none of the buttons are responding for some reason...=/ any ideas? tried the latest update but that didnīt help...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    By restart you mean, turn OFF and back ON (computer reset) or are you using hibernate/stand by ?
    I'd check if the Winamp path is setup right and if winamp is damaged. Also check CPU usage with task manager.
    Ride Runner RR's Myspace
    Feb 2004
    Hmm..you mean in the config file? sure, i can do that! i mean off (itps sends powerdown signal) and on (ignition on, computer starts as normal)
    edit: The strange thing is that when i restarted the carputer, i saw the EQ and Playlist that wouldīt go away until i clicked on any button?
    Quote Originally Posted by guino
    Feb 2004
    nope, path is correct...so thatīs not the issue..=/ winamp is running perfect
    guino's Avatar
    Nov 2004
    Toronto, Canada
    To hide the EQ/Playlist simply run winamp outside RR and close the EQ and Playlist -- they won't show again unless you re-open them. You're basically telling me winamp is running fine OUTSIDE RR ? loading/playing songs fine ? If you can play stuff with winamp outside RR and you go into RR and can't see the songs you had been playing in winamp (in the list) then most definitely there's something wrong with your winamp or path setting..
    You can try the following:
    -Open your winamp folder and delete winamp.m3u
    -Delete resume.ini in RR's folder
    Other then the above, there's no reason why it shoudn't work, so I'd suggest uninstall/reinstall winamp (may be a different version) to see if it works..
    Feb 2004
    yeah, iīll try that,but here comes the tricky part...
    Winamp works, i hear music and all..but RR stops responding once i enter the music menu..? i canīt see the PL, canīt go back to the menu, nothing! all the buttons "respond" to the clicks so (change behaviour as pressed/not pressed) i know the software is still working...but nothing happens when pressing them..
    Raw Wave
    Jun 2004
    On the beach
    Check CPU Usage, sounds like a possible resource problem
    guino's Avatar
    Nov 2004
    Toronto, Canada
    When the buttons are pressed and nothing happens, it is likely that something went wrong during execution of a previous command OR such previous command is stuck waiting for something to happen... Please add this to RR.INI:
    debugmode=true
    then run RR try to use it normally (until you get stuck), kill it and send me the debug.txt file in RR's path. You can remove the line above afterwards.
    Feb 2004
    Seems like youīre right! i tried letting the frontend be, after getting stuck..and after about 3-4mins, it started working! iīll add that line tonight!
  1. Problems playing DVD with RR 03-08-05
    By Passe in forum RR Bug Tracker
    Last Post: 06-24-2006, 12:36 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
  5. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 12:47 AM
