Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Volume & Balance problem
    Jun 2005
    Spain
    I set up RR for using Master Volume as volume control, because it's the only way to control CD playing volume too. But when I exit RR and restart it again, master volume slider went to 0 and balance slider is "left channel". I notice these simptoms with all RR versions and all Winamp versions.
    If (in RR setup) I change the volume control to "WAVE" all works ok but CD volume can not be adjusted.
    Could somebody help me?
    PD: Sorry for my English. I'm better in Spanish
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    A few users have reported this issue... I am yet to figure out why this is happening.. can you (and perhaps other users with the same issue) post the Motherboard or Soundcard model that you're using ? There's nothing in RR to mess with the mixer at startup.. I have never seen that happening (so I can't really de-bug it)... in any case you should be able to make a mixer preset to load at startup to take care of that.. I will double check the code..
    Ride Runner RR's Myspace
    Raw Wave
    Jun 2004
    On the beach
    It happens on both my VIA EPIA 800 mobo and my Shuttle SV24, both running XP Pro. Only happens on a cold boot, works fine if using hibernation.
    I've set my system to run a mixer preset
    Newbie Apexion's Avatar
    Apr 2005
    Alother case.
    I have had this happen on a ASUS P4R8L (Pundit-R) using an SB Audigy 2 NX.
    It only seems to happen on after a failed hybernation though.
    Jun 2005
    Spain
    My mobo is Via Epia MII 1200 w/disabled internal sound card, and a SB audigy2 ZS PCI with KX drivers. Bluetooth drivers never used nor installed.
    Certainly, this issue only happens after closing/restarting RR, returning form hibernation state works fine in my carpc.
    The only issue I sometimes notice after hibernation is the audio browser skin partially shown (one quarter on the right of the screen remains white).
    Jun 2005
    Spain
    A curious note: cold starting RR wiht autoresume enabled, music sounds with right volume & balance, but RR display shows "Volume: 0", but pressing any volume button sound mutes suddenly. After this, pressing volume up button music volume goes right but sounds on left channel only. Switching to mixer, I have to center the balance and then all sounds fine.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This sounds to me like a driver issue.. I can easily make RR force the balance to center when starting up, but this can already be done by loading a preset.. I have personally used a SB Audigy 2 (with Creative drivers) and it worked perfectly.. both on cold start and with hibernation...
    Jun 2005
    Spain
    Driver issue? I don't think so, because running Winamp only instead RR all goes fine from start.
    Low Bitrate happpyg's Avatar
    Feb 2005
    Bunbury, Western Australia
    Smile
    An option to force the balance to center on startup would be great. I don't auto load a preset as it changes the volume level as well. Bit picky I know but I like the volume level returning to what it was when I hibernated.
    Semperon 3200+/512MB/ Seagate SATA2 120GB
    10.2" Xenarc/ Netgear USB Wireless
    M2-ATX/RadioShark
    BU-353 GPS Receiver
    http://www.happyg.mine.nu/carpc/index.html
    guino's Avatar
    Nov 2004
    Toronto, Canada
    So you need that on hibernation too ?? I'll write it down then.. hopefully the "fix" will work (I have no way of testing since it doesn't happen on any of my machines)...
  1. Volume problem
    By Lord_Pall in forum FrodoPlayer
    Last Post: 07-19-2005, 11:55 PM
  2. MP3 Volume Normalization
    By eCarô in forum General MP3Car Discussion
    Last Post: 01-12-2005, 01:09 PM
  3. Replies: 11
    Last Post: 02-11-2004, 11:59 AM
  4. Replies: 6
    Last Post: 11-12-2003, 10:57 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
