Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Music resumes after hibernate but then it stops...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have seen a few reports of this issue happening where after resuming from hibernation the music starts playing but then stops right after. I do have a theory about it but I'd like for any users that have such issue to post below the following:
    1-Type of Sound Card (onboard/pci/usb)
    2-Model/Brand Name of SoundCard (SoundMax, AC97, SB Audigy etc)
    3-Do you have a bluetooth adapter and if so, do you use the WidComm Drivers?
    I believe to have found the issue and I'm working towards trying to solve it but I need your help on finding a definite solution. At first this seems more like a windows/driver issue than a bug in RR.. so solving it will basically be a matter of building prevention against it in RR, and not fixing a "bug".
    Ride Runner RR's Myspace
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    me me me.. I'm having this problem
    ok, its on a dell laptop
    1. onboard
    2. sigmatel
    3. onboard bluetooth using hacked widcomm drivers
    I have also found if I disable the BT in the bios then the sound is fine. So its something to do with the drivers I think of the BT..
    hope u can help
    CdR
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yeah, nobydy else seems to care about this issue lately... but if you don't use the Bluetooth audio as "handsfree" (using mic+speakers) then you can you can simply disable it on device manager (just bluetooth audio) and the problem will go away... it seems that WINDOWS resets ALL sound card handlers after a new sound device is "plugged in" .. which in effect, stops any music/sound playback in process... I believer this is also the reason for some issues when using a USB sound card.. Winamp doesn't have any protection against this issue, but other players (i.e. Mediaplayer) just might.. I'll try to add some sort of detection against this issue as soon as I have some time available..
    Feb 2004
    Manchester
    ok.. update
    I searched around and found a update firmware/driver from dell which they had withdraw because it installed the firmware and drivers in one go.. problem was soon as it finished installing the drivers it told u to reboot, even though it was only halfway done flashing the BT device.. so loads of peeps wasted there bt device..
    anyway I indeed waited and now everything works a treat :-) even allowed me to pair my phone as a headset rather than a audio gateway
    so problem solved.. well for me anyway
    I'm happy again
    thanks
    CdR
    guino's Avatar
    Nov 2004
    Toronto, Canada
    cool... but still doesn't solve it for those with any type of USB audio devices (sound cards, bluetooth etc)... in your case it should be ok simply because you have no USB-based audio devices..
    Feb 2004
    Manchester
    well.. I have yet to plug back in my usb mini soundcard that I use for mic input up front.. will try it this afternoon
    CdR
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I was having this prob too but it wasn't always that way...one thing that I did change was I went from IGLaunch to Skinbedder..
    And from what I could tell...my prob went away...not sure if that what was causeing the prob...maybe when the IGL reconnected my gps mouse at resume, it interfered with RR/winamp??
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    I keep finding my music stopped at odd times but have not managed to tie it down to a definate set of circumstances yet. I do have resume music ticked.
    fwiw
    onboard ac97 on via m10k
    no bt at all
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Mad Ad
    fwiw
    no bt at all
    Any USB devices (Specially those installed with/as audio device) ?
    Oct 2004
    Hertfordshire UK
    only the BU303 and the TS
  1. RR Doesn't Resume Music after Hibernate
    By Wiredwrx in forum Road Runner
    Last Post: 03-24-2008, 04:08 AM
  2. Audio crash after hibernate (USB alerts)
    By Peoples in forum RR Bug Tracker
    Last Post: 03-10-2005, 01:29 PM
  3. No auto resume music and video?
    By organasised in forum Road Runner
    Last Post: 02-10-2005, 09:55 PM
  4. Replies: 2
    Last Post: 11-25-2003, 10:50 PM
  5. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 09:08 PM
