Results 1 to 10 of 10
Thread: rr minimizes when closing cdrip
    Jun 2005
    i have a problem with cdrip, freedrive but not browser.
    after i close cdrip rr is minimized. same goes for starting freedrive.
    the browser seems to work ok (starting and closing)
    what are the things i should look at to get rid of this problem?
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Start getting a look to the command of the close button of the cdrip skin.
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    FLAC J187's Avatar
    Nov 2004
    Boston
    Update your version of RR by going to Start>All Programs>Road Runner>RR Updater
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    yeah, you probably need to make sure you have the latest CDRip and RR release version.. there's a whole FAQ on installing the CDRIP. You also need to make sure you're not running it INSIDE VB (if you're doing any coding)....
    Ride Runner RR's Myspace
    Jun 2005
    yes, well i have the latest versions of everything. i use exit to close cdrip and after this rr reappears in the taskbar, it's just minimized. can i force rr to maximize?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's definitely something wrong with your install man.. either in CDRip.skin or ExecTBL.INI.... this is what you should have in CDrip.skin :
    B07,724,509,75,90,"EXITPLUGIN",""
    This is what you should have in ExecTBL.INI (with YOUR path to CDRip):
    "CDRIP","PLUGIN;RRCDRip;C:\Program Files\Road Runner\CDRip\CDRip.exe"
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    Can you confirm this is what you have ? RR should "restore" itself automatically upon exiting the CDRip plugin. It would only stay minimized if the above is not correct..
    Jun 2005
    yes you were right, typo in the path to plugin. working now.
    some more questions about cdrip:
    mute indicator does not work (no flashy thing)
    songpos slider does not work
    can i close the cdrip skin and use the other pages of rr while cdrip is running in the background? (i am able to play music while ripping, so i figure this should at least be possible)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yeah, as this is a plugin, it does not implement many functions available in RR.. so you won't get the mute indicator or song position unless it is obtained from RR (extra code needed) ..
    The EXITPLUGIN command will basically exit the plugin if it is IDLE, and just make it run on the background if BUSY... the settings in the INI allow you to view the CDRIp again if you close RR and it is still running..
    Jun 2005
    so, does that mean when you leave it running in the background, and you go to ripskin again it reloads the plugin (and stop the ripping that is in progress?)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    no, if the plugin is running on the background and you click CDRIP it will simply re-show the same instance that was already running...
  1. Problem whit cdrip whit rr
    By manung in forum Road Runner
    Last Post: 10-26-2009, 08:27 AM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
  4. Replies: 4
    Last Post: 06-21-2005, 05:09 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
