Results 1 to 10 of 19
Thread: OSK string insert
    Low Bitrate jollyeskimo's Avatar
    Apr 2005
    Toronto
    OSK string insert
    Everything's been running fine and dandy, but the OSK's been behaving a bit weird ever since I switched from pure iGuidance to iGuidance embedded with skinbedder. Basically all I did was add an APPOSK button to my external GPS page.
    When I try to type something into the street name entry window via OSK, the full string displays on the OSK window... but upon entering it, some of the characters see to be missing from the full string. Something like "mississauga" in the OSK window would end up as "missga" in the iguidance text prompt, I haven't used it enough to tell if there's a pattern to it.
    Any thoughts?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    does it happen at all when skinbbedder is not used ? that would tell you if the problem is in RR or skinbedder (or it's settings)..
    Ride Runner RR's Myspace
    Apr 2005
    Toronto
    without skinbedder the missing characters seem to stop, but now I notice that there's a new bug with a definite pattern:
    1.
    string entererd in OSK: "testing"
    string showing in iG field: "testing"
    2.
    string entered in OSK: "testig" + LEFT cursor + "n"
    string showing in OSK: "testing"
    string showing in iG field: ""testign"
    string that semantically should be showing in iG field: "testing"
    See what I mean? the cursor actions seem to do nothing.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    is the above with or without skinbedder ?? If the OSK works fine without the skinbedder than this is not a problem with RR, but with Skinbbeder+IG..
    Apr 2005
    Toronto
    Yeah I guess this isn't an issue with RR anymore, haha
    No matter anyways, finally figured out that iGuidance's blasted OSK only works with 96dpi instead of 120dpi in windows, which makes all of this kind of redundant.
    Aug 2005
    Similar OSK problem
    I am using the standard BMV2 skin. When I click on the WEB link, my I.E. browser opens to google. When I use the OSK to type in the google search, all works well. When I click on the address bar and try and type an address, the text in the OSK appears fine, but in the address bar only the last character appears.
    I added an OSK button to my external GPS window, and this is also the case when I try and use OSK on any fields within Delorme. Only the last character appears in the string.
    Any ideas?
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    seems lots of people are having to add their own osk button to the gps window- shouldnt there be one in the default setup?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by F350
    Any ideas?
    This feature is HIGHLY dependent on the application in question... IE will not allow you to type stuff on the address bar because every character you type selects the entire text on the address bar, and that is then replaced with the next character you type -- THATS WHY THERE IS AN OPEN URL BUTTON! My guess is the same is happening with your Delorme software...
    Aug 2005
    Yes, you are correct about the auto complete fields. And I finally noticed the URL button while working on my skin.
    So is there a work around for this? How would I type text into these auto complete fields in my Delorme software (besides an actual keyboard). I'll see if I can turn this feature off.
    Thanks.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'd have to try and do some real funky API work to try and make it work.. for now the only thing that will work is the Windows OSK (which is not that great for touchscreens).. but you could easily launch it using a button in RR's skin.
  1. OSK... need help/ideas..
    By guino in forum Road Runner
    Last Post: 06-25-2006, 08:49 PM
  2. OSK and iguidance
    By kuo in forum Road Runner
    Last Post: 07-19-2005, 07:31 PM
  3. OSK bug ????
    By tolisn in forum RR Bug Tracker
    Last Post: 03-31-2005, 12:25 PM
  4. Dual OSK Possible?
    By grnikolis in forum Map Monkey
    Last Post: 03-27-2005, 11:24 AM
  5. OSK clobbers comm port?
    By wi77iam in forum Software & Software Development
    Last Post: 03-25-2004, 12:12 PM
