Results 1 to 5 of 5
Thread: XM Problem. Runtime Error 5. Please help
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    So i indtalled RR, and set up XM and anything else corectly, but when i start RR it pops a Runtime error 5 window. and clicking ok closes RR. It has to be XM related, b/c when i disable XM (put 0 as a port) RR is working fine...
    Any solution?
    The cable and the XMD1000 is good, b/c FrodosatalphaX is working fine. Supscription pending... Please help. as i rater use RR than other software...
    THANX!!!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    what's the date on your RR.EXE ?
    EDIT: have you tried to delete or unzip the original xmcache.ini file onto RR's folder ?
    Ride Runner RR's Myspace
    Aug 2004
    Walden, NY
    i have the 8-2*-05 version (*something)
    and no, i don't know where to find the xmcache.ini
    please help...
    Low Bitrate mbayers's Avatar
    Aug 2005
    Pasadena, CA
    Quote Originally Posted by BoyNextDoor
    please help...
    xmcache.ini is in the RR folder. I had a problem related to this file recently with my XMPCR and RR. Basically, I deleted the "old" xmcache.ini file and replaced it with a "new" one from the RR install package. Just a straight file copy operation. Restart RR, and it works from the new file.
    I understood from Guino that RR should create a new xmcache.ini file on its own by getting the channel data straight from the XMPCR. I may have misunderstood, as this was not what happened for me. I had to manually replace the file. After that, it worked fine.
    MBA
    2000 Ford Explorer Eddie Bauer
    CarPC Status: As of 03 Jan., 2006 - installed & running!
    Epia MII-10000
    512 MB RAM
    Lilliput 7" LCD
    Toshiba 40GB HDD
    Panasonic Slim slot-loading DVD
    Holux GPS w/ iGuidance
    XM PCR
    RoadRunner
    guino's Avatar
    Nov 2004
    Toronto, Canada
    there was a bug causing that error on one of the earliest versions (invalid/inexistent xmcache.ini).. if you upgrade to the latest version, you will not have the same problem..
  1. XM Equipment CHEAP! XM Direct $29!!!!
    By hevnsnt in forum General Hardware Discussion
    Last Post: 04-11-2006, 09:18 PM
  2. XM Driver Install Problem
    By MikeH in forum MacCar
    Last Post: 04-24-2005, 11:22 AM
  3. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 02:18 PM
  4. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
  5. Pioneer XM Tuner problems
    By techy101 in forum Car Audio
    Last Post: 09-20-2004, 10:10 PM
