Results 1 to 5 of 5
Thread: RR and MM - Location ETR ETA
    Apr 2005
    hi, i'm using MMonkey with CDRSkull skin.
    I've noticed that the text field in BMV2 (or BAV2) at the bottom don't display Location, ETR and ETA.. it only displays N/A
    I've looked with skineditor in BMV2 "code" and it calls the message "MM;street" or "MM;ETA"... Is there a problem with this commands ?
    May 2005
    Derbyshire, UK
    I haven't looked into this fully but you need to enable monkeytalk or something along those lines...
    Search for that and see what you find...
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    May 2005
    Derbyshire, UK
    I think it's this section of the settings.ini file in C:\DestinatorApps\Mapmonkey\
    [Plugins]
    //Allow custom apps to interact with the frontend?
    Enabled=Yes
    ListenPort=1811
    Old setup
    New setup
    May 2005
    Derbyshire, UK
    Old setup
    New setup
    Apr 2005
    thank you and sorry but i didn't found this thread by guino..
    I'll try it immediatly.
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 03:02 PM
  2. MM Commands for displaying data from MM in RR
    By mcflurri in forum Road Runner
    Last Post: 08-04-2005, 02:20 PM
  3. RR, MM and Girder
    By Prem in forum Road Runner
    Last Post: 08-04-2005, 04:36 AM
  4. ETR and ETA value N/A
    By slimmegane in forum Road Runner
    Last Post: 04-16-2005, 02:37 PM
  5. Creating RR Skin For MM
    By studly_steve007 in forum Map Monkey
    Last Post: 04-14-2005, 02:20 PM
