Results 1 to 5 of 5
Thread: RR pulling focus away when it receives customlabels
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi m8, been playing around about, and noticed the reason I have been having problems with the games skin I'm doing is that when FD sends a customlabel to RR, RR grabs the focus. I have again looked through my FD code and cant see anything on my side. When FD isnt running then RR is fine.
    CdR
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Are those customfd codes or what ? I remember that I had to make RR pull the focus on SDK commands, and that I also disabled this focus deal for the FD commands -- if you tell me the codes you're trying to use, I can definitely look it up and implement the changes if need be.
    Ride Runner RR's Myspace
    Feb 2004
    Manchester
    I will have a play and locate which one/s its happening on thanks m8
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hi CDR, I've double checked and basically, if your SDK command starts with "SETLABEL" then it won't take away the focus from FD.. but stuff like: "PLAY||SETLABEL;..." will take away the focus, as opposed to "SETLABEL;...||PLAY" will not take away the focus.. I am still unclear why the focus is set to RR but I think it has to do with the plugin interface.
  1. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  2. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 05:05 AM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 01:21 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
