Results 1 to 3 of 3
Thread: browser.rrl / CD problems...
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    A few things I've noticed...
    I am no longer able to play .CDA files (added as extension) when I'm using my cd drive in the browse.rrl fashion... I see the file list, I can add all files to the playlist but none of them play! I am able to play them outside of RR in WMP, but not in winamp.... (I just realized this... I have CD extension assinged to winamp, and I have the Handle CDs option ticked in Winamp config.... any ideas?)
    Anyways that isnt RR related, I just discovered, but this is :
    The BACK command to go up to the parent directory doesnt work when I go into the audio CD... I am unable to come out of it....
    Also, when I dont use hidedots=true (I plan on always using it but though I'd report this anyways) the browse.rrl stuff comes ABOVE the ".." so it looks kind of werid, like this:
    Code:
    [    Audio CD    ]
    My Ripped Cds
    Concerts
    etc
    etc
    unless you think this makes more sense, but it looks a bit confusing to me...
    - One general query now, is it possibel to limit browsing to the directory defined in RRConfig for music/video? (Right now if the user clicks .., or the BACK button, he can go upto my C:\, whereas I'd like to keep him locked into the directory defined in RRConfig (for video and audio separately) anmd its subdirs...
    Thanks for everythign!
    Roy
    2005 Range Rover 4.4
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll take a look at that... I'm trying to fix any standing issues and post a release, then it will be awhile before another release as I'm planning to re-do the audio interface..
    Ride Runner RR's Myspace
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I just tested the latest version of RR with the CD player and it works fine.. if you can't browse the CD (and see the TRACK files) then it's likely your CD drive changed and/or it is not the same letter you setup in browse.rrl
    The Browse.rrl links ARE MEANT to show above anything else in the list. In theory you can point your mp3 path to an empty folder, make a browse.rrl file in there and place the folders in whatever order you want it to be displayed in there (could make it the same as it used to be listing your folders directly -- but it your own order). The problem with limiting the folder path is that it would also limit access of where the browse.rrl could link to -- so this will not be implemented. If you organize your drives well enough this shouldn't be an issue (you can always make virtual drives to organize it as well).
  1. How do I setup the CD Rip plugin ?
    By guino in forum RR FAQ
    Last Post: 12-18-2008, 07:28 AM
  2. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 07:12 PM
  3. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 04:04 PM
  4. Standby while playing cd on firewire cd player
    By psyclobe in forum Media Engine
    Last Post: 06-02-2004, 11:10 PM
  5. GM Remote CD player slot
    By Chairboy in forum General Hardware Discussion
    Last Post: 05-10-2004, 09:49 PM
