Results 1 to 2 of 2
Thread: GPS / Map Point current position
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    I've found an issue where by I have the show current GPS position enabled (I want it enabled all the time).
    When my Car PC starts and goes into GPS mode, if I current don't have a lock (which is 99.99% of the time) and then get a lock it does not show the current GPS position. It only shows the current position if I then go into POS Mode, Toggle current GPS Position.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads:
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    this is by design... if you go into the GPS screen with Mappoint and you don't have a GPS lock, the "SHOW GPS POS" will be OFF. when it aquires signal, you should then click on "SHOW GPS POS" to turn it on and show you where you are...
    Ride Runner RR's Myspace
  1. Replies: 91
    Last Post: 11-07-2006, 04:47 PM
  2. Map Point 2004
    By Mellman in forum GPS
    Last Post: 05-17-2005, 01:15 AM
  3. Replies: 2
    Last Post: 03-23-2004, 02:22 PM
  4. Replies: 4
    Last Post: 02-26-2004, 09:52 AM
  5. Map Point
    By Striker169 in forum GPS
    Last Post: 10-29-2003, 11:01 AM
