Results 1 to 4 of 4
Thread: help
    Oct 2005
    Tulsa, OK, USA
    help
    when i try to run RR i get error MSVBVM60.DLL error.
    to be exact :
    RR.exe - Unable to locate component
    This application has failed to start because MSVBVM60.DLL was not found. Re-installing the application may fix this problem.
    i have tried uninstall, reinstall. uninstall-reboot-install-reboot still getting the same error.
    has anyone seen this or know how to fix it ??
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Check the install FAQ and download the Visual Basic Runtime from the link...
    How do I install Road Runner ?
    You should also check ALL the other FAQs...
    Ride Runner RR's Myspace
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Got the same error after clean disk, defrag, check disk....
    08 Lincoln Navigator www.mobiteklink.com
    May 2005
    Haven't you guys used interweb before? A simple google search could have helped you.
    Click this link, download the zip, unpack the dll in your windows\system folder.
