Results 1 to 8 of 8
Thread: RR does not respect Y position after hibernation
    Sep 2005
    I have modified the size and position of the Alpine Skin to acommodate to my screen and the frame where is fitted in.
    The problem comes when the pc comes from hibernation.
    The interface goes up not respecting my 20 on Y position. So I have to exit RR and open again to see it correctly.
    Also, since I changed the size and position, the video don't display correctly. To be more precise, its displaced down.
    Its a bug or I'm doing something wrong?
    Help gino!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I haven't seen any problems with this, but I can take a look at it when I have a chance...
    Ride Runner RR's Myspace
    Sep 2005
    Ok, this is my General.ini file of Alpine Skin:
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=580
    XPosition=0
    YPosition=20
    ApplyToVideo=True
    ApplyToVisu=False
    AutoSwitch=True
    DayTime=08:00:00
    NightTime=20:00:00
    GammaDayRed=0
    GammaDayGreen=0
    GammaDayBlue=0
    GammaNightRed=-40
    GammaNightGreen=-40
    GammaNightBlue=-40
    I tried to change ApplyToVideo=True to False, but nothing changes.
    What does exactly this parameter?
    The only way to see video correctly centered is having X Y to 0 but no good for me. Other values displace the overall image.
    I'm using the latest release of RR and I tried on another PC and the results are identical.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I only found an issue when using MPC... I have put out a little "fix" for it on 10-31...
    Sep 2005
    So where the problem can be?, because the problem still ocurr and I tried with to different computers, one the carputer with an epia1000 and other P4630 64bit, both with windowsXP 32/64.
    What could be responsible of this? Can I displace the image outside RR? In the WMP or winamp viewer for example?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    First, if I were you, I'd try VERY HARD to change the SCREEN settings to better fit the physical placement of your LCD...
    For all I have tested, I could not find any issue with the video with the same exact settings you posted above (which did work)... but if you still have issues, then I'd suggest trying a different skin (and I did try different skins as well)..
    May 2005
    sometimes when i restore from hibernation, my skin appears half hide on X position
    Renault Megane Coupé Cabriolet
    P3 550 mhz 256 mb RAM 15 gb hd, dvd.
    gps handsfree parrot ck3300
    windows xp sp2
    road runner
    map monkey and viamichelin mapsonic
    Touchscreen 7" fully motorized in-dash
    Sep 2005
    yeah, I tested with other skins and I got the same results.
    Also, I cannot change the resolution of the screen 800x600 wich is a lilliput 7" 2005.Tried to adjust with powerStrip, but I have not much margins without having it out of synch.
    For the home PC, I have another very different res 1280x1024, same problem.
    If your for example change the X and Y pos, the video displaces the same ammount in X and Y not being aligned with the skin.
    Don't know what the problem can be, but in the meantime, I just centered the skin and adjusted some aspects of MM wich is ok while I cannot get a solution for this.
    Nobody else has this problem?
  1. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  2. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 05:05 AM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 01:21 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Alternate date/time formats in RR
    By drait in forum Road Runner
    Last Post: 02-01-2005, 11:53 AM
