Results 1 to 2 of 2
Thread: ExecTBL.ini bug?
    Mar 2005
    Germany
    ExecTBL.ini bug?
    Hi,
    i run into problems trying to use the exectbl.ini with the added line:
    "MAIN","LOAD;fmmenu.skin",FM
    i looked into the code and found in the sub exec():
    Select Case DT(2)
    Case "xm"
    If LCase(CODE) = LCase(DT(0)) And XMON Then CODE = Trim(DT(1))
    Case "sr"
    If LCase(CODE) = LCase(DT(0)) And SRON Then CODE = Trim(DT(1))
    Case "fm"
    If LCase(CODE) = LCase(DT(0)) And RadioON = Frm.Tag Then CODE = Trim(DT(1))
    Case "mm"
    If LCase(CODE) = LCase(DT(0)) And MMRunning = Frm.Tag Then CODE = Trim(DT(1))
    Case Else
    If LCase(CODE) = LCase(DT(0)) And DT(2) = Frm.Tag Then CODE = Trim(DT(1))
    If LCase(CODE) = LCase(DT(0)) And LCase(LabelInfo("status")) = DT(2) Then CODE = Trim(DT(1))
    End Select
    guino i think you had to remove the '"=frm.Tag" after RadioON and MMRunning???
    hematec
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you're 100% right... I'll make the change... thanks..
    Ride Runner RR's Myspace
  1. Bug Tracking List
    By d_sellers1 in forum MMC Bug Tracking
    Last Post: 04-01-2007, 10:02 PM
  2. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
  3. Neocar External Application Bug Fix!
    By reddeath30 in forum NeoCar Media Center
    Last Post: 04-07-2005, 08:25 AM
  4. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 01:27 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
