Results 1 to 9 of 9
Thread: LOADIMG bug?
    Jan 2004
    Champaign, IL
    LOADIMG bug?
    Hello:
    I'm using Chuck's skin, and particularly like the weather screen with detailed maps, downloaded from weather.com. It seems there is a bug in the LOADIMG command: using Chuck's original code, the image is shifted to the right and down when loaded in the same place as the image that is first loaded using IMG. If I exit the screen and then re-enter (keeping it in memory) the second image then appears to be in the correct place. If I artificially adjust the position used by LOADIMG on first load, when I return to the screen those images will be shifted to the left (first compensated for shift to right by moving to left, result is shift to left).
    The arguments for LOADIMG are simple, pretty sure I got that right. Am I missing something? Thanks!
    Chuck's skin code:
    /, I, x, y, w, h, Code;INDICATORCODES
    IMG,199,98,806,415,"600.jpg",,,,,,,,,
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,23,100,150,60,"LOADIMG;199,98,806,415;600.JPG;OU T",""
    B,23,157,150,60,"LOADIMG;199,98,806,415;100.JPG;OU T",""
    B,23,329,150,60,"LOADIMG;199,98,806,415;TEMP.JPG;O UT",""
    B,22,386,150,60,"LOADIMG;199,98,806,415;FOR.JPG;OU T",""
    B,23,214,150,60,"LOADIMG;199,98,806,415;SAT.JPG;OU T",""
    B,23,272,150,60,"LOADIMG;199,98,806,415;THUN.JPG;O UT",""
    B,23,444,150,60,"LOADIMG;199,98,806,415;PRE.JPG;OU T",""
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Your commands are WRONG. You're using commas as separators for the loading position, but instead you should be using semi-colons ( ; ). I can only assume that it would the images in the wrong place (if at all).
    Ride Runner RR's Myspace
    Jan 2004
    Champaign, IL
    Thanks for the response. Nope, that's not it. I notice that if move focus away from Road Runner then back to it the images are magically resized and placed where they should be. This happens on my test system (IBM T41) and the machine in my car. Try it out with Chuck's skin and let me know if you experience the same problem. Or just take my word for it that there is another problem.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll take a look when I have a chance ... sounds like I need to add a screen refresh to the LOADIMG command.
    Jan 2004
    Champaign, IL
    Thanks, that would be great. -- Ryan
    May 2005
    Vienna, VA
    While we're on this topic, I've found a bug with the IMG command.
    In resized skins (for example, those originally 800x480 that are resized on the fly to 800x600 through a setting in general.ini), the IMG command for ON and DOWN layers don't work properly. The image is not shown where it's supposed to be.
    To recreate this bug, you can use my 800x480 CFX skin and edit general.ini to stretch it out to 800x600. Then hit the "MUTE" button (third one from bottom left). you should see a blinking Red X over that button but it's not there.
    Now edit general.ini to put it back to 800x480 and this problem is gone. Now, you'll see the blinking red X.
    This is the code where I define that red X.
    IMG,158,437,41,29,"mute_indicator.gif",ON
    IMG,158,437,41,29,"mute_indicator.gif",DOWN
    Jan 2004
    Champaign, IL
    That sounds like a more accurate (and logical) description of the problem, as the skin I am using is Chuck's, resized from very big to 640x480. Thanks for chiming in!
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Just to resurrect an ancient thread and to verify that this bug is still active. The bug comes to the surface when the skin has been resized. The problem is as described above (post#6).
    The road is long but we are getting there.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Just fixed this bug, thanks.
  1. Bug Tracking List
    By d_sellers1 in forum MMC Bug Tracking
    Last Post: 04-01-2007, 11:02 PM
  2. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  3. Neocar External Application Bug Fix!
    By reddeath30 in forum NeoCar Media Center
    Last Post: 04-07-2005, 09:25 AM
  4. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
