Results 1 to 4 of 4
Thread: labels dont hold relative position after skin stretch
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    when u resize a skin, the labels dont maintain there relative position.
    Look at the screenshots and pay attention to the play arrows, the point on the arrow should line up in the middle of the button where the color changes.
    beer replenishment fund
    mp3car live search
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I can see your concern.. I'm a bit confused though in regards to the PLAY arrow.. is that a label ??
    Anyway, at first, I made the code in RR automatically resize the fonts of the skin relatively to the scaling used on the original size of the skin... the problem is that the results were not satisfactory in a few resize modes (i.e. X resize and no Y resize).. so I scratched off the idea of resizing fonts from the beginning.. which means that RR will not resize any Fonts, and that will make it so it seems the fonts are "shifting" simply because the top left position will be scaled as it should, but the font will stay in the original size -- and will be "bigger" (relatively to the image itself), or smaller like in the case you have showed above (most likely because your original skin is 800x480 and you streched it to 800x600 -- instead of your original being 800x600 and reducing it to 800x480).
    Normally, I'd suggest chosing font position/sizes to where they'll work on either screen resolution, but the best thing would be to have a set of .skin files fot 800x600 and another set for 800x480.. The images can still be the same.
    Ride Runner RR's Myspace
    Aug 2003
    Chicago
    yeah the arrow above the play is a label, using the wingding font. I think im just going to get them in position to where they are correct under 800x600, thats should be good enough, or maybe make 2 sets like u suggest since i allready have it for 800x480. Is there any kind of way to resize a skin (not the images), so all the .skin files are set for X res and saved.
    either way, its not a real huge issue, i never noticed it till i did this skin and noticed the arrows not lineing up where they should.
    mp3car live search
    guino's Avatar
    Nov 2004
    Toronto, Canada
    since you're scaling up, it may be just as easy as increasing the font size of your labels (search/replace should do it).. I can recall someone making a little tool to resize the data in the .skin files.. but don't remember it being available for download.
  1. Thoughts on skin design guidelines?
    By Arathranar in forum RR Skins
    Last Post: 06-13-2005, 06:54 PM
  2. Rescaling skin an song position slider problem
    By Passe in forum RR Bug Tracker
    Last Post: 02-24-2005, 12:34 AM
  3. Frodoplayer 1.0.9 Skin Released
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 02-13-2005, 11:38 PM
  4. Replies: 10
    Last Post: 11-01-2004, 08:28 AM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    Last Post: 10-17-2004, 10:50 PM
