Results 1 to 8 of 8
Thread: phoco intergration, latest ver issues
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    a few long standing off/on issues with phoco intergration.
    Although the latest release brought some more stability etc, i still find these problems below.
    1. Error opening com port on cold boot. If i shutdown RR, and run PhoCo stand alone, it works fine. Then afterwards RR loads phoco fine.
    2. There is a pretty long wait time between phoco loading, marked by the bat and signal sliders working and hearing the loading complete loading sound that phoco makes, to the time i actually see my phone book. I know that phoco is completely loaded as the sliders work, the remote mouse works, basicly everything except i cant see the phone book till like 3-4 min later.
    Previous versions of RR showed the phonebook same time as the bat and signal meters were working.
    3. Still recieve the "failure to load resources" error apon exit of RR when it tries to shutdown PhoCo. This dosent happen everytime, but often.
    4. When a phone call is started, the call out screen is shown almost instantly and things go as expected. But there seems to be some slight confusion either with PhoCo or RR as to weather im still on the phone. When i end the call, the window will go away, then a few sec later, it will pop back up for a few seconds then go way on its on. During one phone call (outgoing) i see the window about 3-4 times. Not a huge issue.
    5. Contents of the phonebook. Prob not a RR or PhoCo issue, user error likely. But the phone book in RR, compared to the Phonebook in PhoCo stand alone, compared to the phonebook in my phone, are all different. In the RRConfig.exe where is says to point to your address file, what file is this? I just point it to the PhoCo install dir and assume that RR will find whatever file its looking for. Is this the right way to set this up?
    6. Not a bug or anything, but is there a skin that i can download "rightnow" that has working SMS support? I want to add it to my skin but am not sure at all as to how its supposed to be setup, what .skin files are being called etc.
    Thanks.
    beer replenishment fund
    mp3car live search
    Sep 2005
    UK
    I have also noticed problems 1 -5.
    7. In addition phoco by itself will start an audio gateway service when I am on a call. However phoco through rr doesn't. This is using a multi bt service phone so the comm port stays connected during this time.
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by liquid_smoke
    Thanks.
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    May 2005
    Vienna, VA
    I can confirm #1. Phonebook takes about 3 minutes to show up for me as well.
    8. When a call comes in, the popup displays an old number from some previous call. Then after about 3 rings, it'll be updated with the correct number. This is somewhat annoying and causes you to sometimes accept or reject the wrong call.
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Also add after coming out of hibernation I have to shut down RR and open back up for PhoCo to connect.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    This preview release of RR would have to solve some issues of the current phoco integration.
    Sep 2005
    UK
    thanks robbie, is this supposed to solve my issue with the audio gateway not starting?
    Aug 2005
    Italy
    Quote Originally Posted by Cruizer
    Yes, it will have to solve your issue with the audio gateway.
    Try this:
    Edit your phone profile in PhoneControl using the Extended Configurator and set the option UseBTManager to False or more simply use Wizard and when it ask for to select how do you want PhoneControl to control the headset of your phone, answer "Don't control the headset".
    Well, at this point, edit your RR.ini file and add this two settings:
    connecthsp=true
    btdevicename=My phone
    where "My phone" is the Bluetooth name of your phone.
    Let me know if this solve your issue.
  1. Audio gatway issues with Road Runner and Phoco
    By Cruizer in forum Road Runner
    Last Post: 03-15-2006, 11:06 AM
  2. Phoco intergration?
    By djmickyg in forum Road Runner
    Last Post: 12-14-2005, 09:11 AM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. PhoCo intergration/ call pop up
    By liquid_smoke in forum Road Runner
    Last Post: 08-19-2005, 01:28 PM
  5. Latest iguidance Ver.?
    By Defiler in forum GPS
    Last Post: 11-24-2004, 02:37 AM
