Results 1 to 10 of 10
Thread: Problem also with MM commands in RR skin
    Mar 2006
    Italy
    Ok, another problem for me...hope the last (RR is perfect for my car pc).
    In Bmve36 skin I add a field L and try to insert the command "DISTANCE" from MM. Nothing.....
    I Try also other commands but same result.
    My gps work with nmea and other function like direction works fine in skin.
    Sure I forget something in configuration but I don't understand what....
    Thanks for help....
    Alex
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try the BMV2 skin see if the Location/ETA/ETR info is displayed correctly from MM, if not, then you need to set MM correctly -- this is explained in the GPS FAQ (you probably don't have the TCP connections enabled, but read the whole section on MM to be sure)
    PS: This is assuming that you're trying to DISPLAY info from MM -- which is in no way a "COMMAND".
    Ride Runner RR's Myspace
    Mar 2006
    Italy
    In BMV2 skin ETA, ETR and location works fine....i try to change location (MM;STREET) with distance to next turn (MM;DISTANCE) (try also DISTANCE only) but this don't works.
    I have Destinator 3 (not SDK)...possible that strings for Destinator 3 are different?
    Alex
    guino's Avatar
    Nov 2004
    Toronto, Canada
    well, if ETA/ETR/SREET work, then "DISTANCE" should work but you probably have not created a route in order for it to display that information -- you MUST have a GPS lock for it to work as well.
    Mar 2006
    Italy
    I create a route, MM tell me first turn with distance to it but on RR skin nothing.
    What do you mean with "you MUST have a GPS lock for it to work as well" ?(sorry my english is not so good)
    Alex
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Do you have the GPS installed and it is reporting your position propperly in MM ? without the GPS connected with good signal it will NOT work.
    Mar 2006
    Italy
    RESOLVED!!!!
    .....possible that GPS don't work fine before...change settings and now all ok.
    Only last question: when I turn off gps, in DISTANCE field and in STREET field in RR skin compare "N/A"...is possible to eliminate this? (I have that fields in MENU skin....)
    Another thanks for your help........
    Alex
    May 2005
    How have you solved that problem? And whta with the N/A this will interesst me too
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the Car: N/A and Out: N/A can be removed by commenting/removing 4 lines in menu.skin and any other screen that you'd like to remove it from, alternatively you can install a temperature sensor (link on my site) to make them actually work.
    Mar 2006
    Italy
    Sorry..I don't explain well.....
    N/A compare in "STREET" and in "DISTANCE" fields when GPS is not in use...
    It is possible to mascherate it when i turn off GPS?
    Alex
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  2. Replies: 3
    Last Post: 03-20-2006, 10:32 PM
  3. MM doesn't send complete Street info to RR?
    By davidovi in forum MM Bugs
    Last Post: 11-17-2005, 05:08 PM
  4. RR, MM and Girder
    By Prem in forum Road Runner
    Last Post: 08-04-2005, 04:36 AM
  5. Creating RR Skin For MM
    By studly_steve007 in forum Map Monkey
    Last Post: 04-14-2005, 02:20 PM
