Results 1 to 4 of 4
Thread: Xm Line Ine Plugin Bug
    Low Bitrate I302K's Avatar
    Mar 2006
    NY
    Ok First Thing First I'm Using The A Line In Plug-in With My Xm Since My Sound Card Does Not Support Up Mixing. After A Few Min Of Listening To Xm Radio On Any Chanel In Any Area It Sounds Like The Buffer Is To Full And Gives Me A Scrambled Sound Hissing Kind. For A Few Seconds. Then Back To Normal. This Is Happening On My And A Friends Carputer. Any Ideas?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    never seen that happening. However, I have seen both XM and SIRIUS do similar effects every now and then when for instance driving slowly under an overpass or closeby buildings, houses, etc. But I would suspect that it could be the Line In Plugin if your machine is reasonably slow -- check your CPU load, if it's under 50% most of the time, that shouldn't be the case, meaning it's probably a reception issue, but you can verify by parking somewhere with excellent signal and listening for some time to see if the signal scrambles..
    Ride Runner RR's Myspace
    Mar 2006
    NY
    Tested it infront of my house for over half an hour and same thing the cpu speed is a around 55-60. Like i said before this is hapening on to carputers mine and goosey2099's.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The CPU load is quite high for your machine apparently.. If you're using 48Khz 16 bits etc, try reducing it to 44Khz for instance.. or 22Khz at least to see if the issue goes away. If it doesn't try switching the output plugin in winamp alternating between the directsound and waveout ones.. You can also try playing with the settings of the input/output plugins such as priorities, buffers etc. I've seen network cards and other hardware interfering with playback of CPU intensive content (Video), and can't see why this couldn't be happening there too. If everything fails, you should try disabling network cards and other devices at least just to verify if they're interfering with anything.
  1. Replies: 1
    Last Post: 11-03-2004, 08:39 PM
  2. Techies - matching line output levels ???
    By slushieken in forum Car Audio
    Last Post: 09-10-2004, 03:57 PM
  3. Question on Line Out of M10000 and Audigy NX
    By Mears in forum General Hardware Discussion
    Last Post: 06-10-2004, 04:00 AM
  4. Easy way to mute/unmute line in ?
    By liquid_smoke in forum General Hardware Discussion
    Last Post: 12-31-2003, 01:02 AM
  5. Help With Lorty's Plugin
    By SexyCompGeek in forum Software & Software Development
    Last Post: 07-23-2000, 12:51 PM
