Results 1 to 6 of 6
Thread: RR hangs if OSKTOVAR is called from a popup menu skin
    May 2005
    Vienna, VA
    Like the title said, if you call OSKTOVAR from a popup menu skin, RR will hang.
    Likewise, if you call "MENU;mymenu.skin" from another menu skin, RR will hang.
    Also, not a bug but when we call OSKTOVAR, can we have the current content of the variable populated in the OSK? Or maybe it should be an option.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should refrain from doing those things.. instead you should do something like:
    "EXIT||OSKTOVAR..."
    or
    "EXIT||MENU;..."
    the above should work -- there are just limitations as to what can/can't be done with a menu.
    PS: I'll see if I can make that an option.
    Ride Runner RR's Myspace
    May 2005
    Vienna, VA
    guino, I have an external app that might load a popup menu in RR when an event happens (for example, USB stick inserted). The problem is the app has no idea if RR currently has another menu open already.
    Of course I can send an EXIT before loading the menu but if RR doesn't have a menu open, it'll go back one screen, which will be annoying.
    Maybe when loading a new menu, RR should explicitly close any currently open menu. That or have a command that closes a menu but doesn't go back on screen if one doesn't exit.
    Thanks for the support.
    (I'm working on the next version of the CFX skin, BTW, so that's why I have all these questions/requests lately. Please bear with me. )
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll see what I can do.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've added prevention against this issue.
    May 2005
    Vienna, VA
    great. thank you.
  1. RR Web Cam Skin Help
    By babyface in forum Road Runner
    Last Post: 05-20-2013, 03:47 AM
  2. Simplistique Skin Release - download and screenshots
    By lloydy in forum RR Released Skins
    Last Post: 05-04-2013, 10:58 AM
  3. LSX....formerly LS3.0
    By liquid_smoke in forum RR Skins
    Last Post: 04-12-2007, 01:36 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Replies: 7
    Last Post: 07-01-2005, 03:29 PM
