I've applied the changes. Thanks.
I've found a little issue with sliders style in RR. In Skin Commands.txt is indicated an images range from 0 to 20 (21 images), but i've noticed that in some sliders (main volume, balance, and all the mixer levels) the real range is from 0 to 19 (20 images).
I think that the problem is caused by some rounded values inside the code.
Guino, may I suggest these changes in modMixer.bas:
Public Sub DoVol(ByVal Idx As Integer, Optional ByVal UP As Boolean = True)
'Get Vol%
VolPct = MixerState(Idx).MxrVol / 655.36
'If No Volume Table
If UBound(VolTable, 2) = 0 Then
'Set Volume
MixerState(Idx).MxrVol = VolPct * 655.36
AdjustOutput Idx: GetMixerInfo
and these ones in frmSkin.frm:
Public Sub UpdateSliders()
Case "balance"
Value = Balance * 655.36
Case "freq1", "freq2", "freq3", "freq4", "freq5", "freq6", "freq7", "freq8", "freq9", "freq10"
Value = 65536 - WinAMP_GetEQValue(Val(Mid(.CODE, 6)) - 1) * 1040.25
Case "preampvol"
Value = 65536 - WinAMP_GetPreAmpValue * 1040.25
'Set Background (if any)
If .Style <= UBound(Styles) Then
BackPath = Replace(SKIN_PATH + Styles(.Style), "*", CStr(Value \ 3120.76))
Ride Runner RR's Myspace
I'm still seeing a similar problem - not all images are shown in the right order. The sequence seems to show image 3 twice, and not show 20 at all.
It appears that there are 21 steps between bottom and top - just not the correct images associated with them all.
Does anybody else see this behaviour?
Ian
What slider code are you using to test it ?
Also, the above could easily happen for instance if RR could not load image 20 for instance. I have seen compressed GIF files that don't work in RR for instance, so in doubt, swap the number of two files and see if both files do work in different positions.
I'm seeing it with all the mixer sliders in the E36 skin.
I've tried renaming the affected gif images, and deleting them and recreating them, but there is no change
Ian
I hate to wake up a dead topic but this fits my problem to a T. I can't seem to find an answer to this problem. All the sliders seem to repeating postion 0 twice or something and position 20 is isn't being read. It also does this for the clicking position...for example if I click on a region in a song the bar moves to the region previous to the one I click on. Anyone else having this problem?
This issue can be fixed easily by changing this two lines in the code, but this could cause that the previous skins need to be fixed.
Case "songpos"
If XMON Then
If XMTrackTime > 0 Then Value = ((XMTime + Timer - XMTimer) / XMTrackTime) * 65535 Else Value = 0
If Value > 65535 Then Value = 65335
Else
Value = (Player.GetTrackPosition / Player.GetTrackLength) * 65536
If Value > 65536 Then Value = 65336 <-- ADD THIS LINE
End If
BackPath = Replace(SKIN_PATH + Styles(.Style), "*", CStr(Value \ 3120.76)) <--CHANGE THIS VALUE
If ImgBack(c).Tag <> BackPath Then
'Load new image
Set ImgBack(c) = New cBitmap
ImgBack(c).FromFile BackPath
ImgBack(c).Tag = BackPath
End If
'Draw Back
DrawIMG DCPic(4).HDC, (.x * W) / OW, (.y * H) / OH, (.W * W) / OW, (.H * H) / OH, ImgBack(c), &HFF00FF
End If
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Umm....thanks Robby. Excellent skin by the way! I just wish I knew how to get to the code to fix it![]()
Seriously....how do I get to that code to fix it? I assume it's in the RoadRunner exe but I did some searching and from what I can tell it's rather difficult to change a compiled exe. I know nothing about coding.
The changes must be applied in the source code, then recompiled in a new binary.
