Results 1 to 10 of 11
Thread: CPU load label issue when...
    May 2006
    CPU load label issue when... the skin also has a cpu load slider... (label is always 100% but slider display a low load) why? the same thing with volume works great!!!
    What can I do?
    Guino, help me please!!!
    May 2006
    Any suggestions?
    This is my skin... the right slider is the cpu occupancy, in the bottom right there is the cpu label... always 100%
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    does the CPU slider work ? cause it's the same code. Is this a NT machine or 98 ? If you can, I'd test it on a different machine to see if it works.. It works fine here.
    Ride Runner RR's Myspace
    May 2006
    the cpu slider works great, the cpu label not. tested on 3 different pc, all with Wxp Sp2.
    This is my main.skin:
    MEDIACAR Skin
    MEDIACAR F-CNS(800X600Stretched)Menu Skin
    MENU_OFF.jpg,MENU_OFF.jpg,MENU_ON.jpg,MENU_DOWN.jp g
    /, F, x, y, w, h, Movie name
    F,270,10,268,246,"clock.swf"
    /, A, x, y, w, h, color;RGB
    A,131,-1,538,374,
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,13,546,98,14,200,155,147,14,"Kometenmelodie 2:B","=VOL:","CENTER"
    L,684,546,98,14,200,155,147,14,"Kometenmelodie 2:B","=CPU:",
    L,13,565,103,19,210,200,160,20,"Kometenmelodie 2","VOLUME","CENTER"
    L,684,565,103,19,210,200,160,20,"Kometenmelodie 2","CPU","CENTER"
    L,159,477,483,16,210,200,160,16,"Kometenmelodie 2","TAGALBUM","SCROLL-CENTER"
    L,159,442,483,29,200,155,147,30,"Kometenmelodie 2:B","TAGTITLE","SCROLL-CENTER"
    L,159,415,483,21,140,150,170,22,"Kometenmelodie 2","TAGARTIST","SCROLL-CENTER"
    L,323,503,163,15,200,155,147,14,"Kometenmelodie 2:B","KBPS","CENTER"
    L,486,503,54,15,140,150,170,14,"Kometenmelodie 2","=Len:","LEFT"
    L,164,503,53,15,140,150,170,14,"Kometenmelodie 2","=Pos:","LEFT"
    L,540,501,98,17,140,150,170,18,"Kometenmelodie 2","TRACKTIME","RIGHT"
    L,217,501,106,17,140,150,170,18,"Kometenmelodie 2","CURRENTTRACKTIME","LEFT"
    /, Y, Back Slider file path
    Y01,"lslider\slider_*.gif"
    Y02,"rslider\slider_*.gif"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S,132,347,536,27,132,347,536,27,H,05,"miata.gif",8 5,"SONGPOS",
    S,139,384,20,140,139,384,20,140,V,01,"lslider\poin ter.gif",013,"MASTER",
    S,642,384,20,140,642,384,20,140,V,02,"rslider\poin ter.gif",013,"CPU",
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,2,2,125,88,"EXITMENU",
    B,2,188,125,88,"VOL+",
    B,2,281,125,88,"MUTE",
    B,161,381,65,25,"MUTE",
    B,2,374,125,88,"VOL-",
    B,2,468,125,60,"GAMMAIND",
    B,130,534,85,63,"PREVTRACK",
    B,220,534,85,63,"FRWD",
    B,312,534,85,63,"PLAY",
    B,403,534,85,63,"STOP",
    B,494,534,85,63,"FFWD",
    B,585,534,85,63,"NEXTTRACK",
    B,673,2,125,88,"GPS",
    B,673,95,125,88,"AUDIO",
    B,673,188,125,88,"LOAD;Video_Player.skin",
    B,673,281,125,88,"LOAD;menu2.skin",
    B,673,374,125,88,"MIXER",
    B,673,468,125,60,"VISU",
    /, I, x, y, w, h, Code;INDICATORCODES
    I,233,381,75,25,"ONLINE"
    I,315,381,72,25,"!NIGHTMODE"
    I,390,381,78,25,"REPEAT"
    I,471,381,92,25,"SHUFFLE"
    B,566,381,73,25,"SCANMODE",
    I,566,381,73,25,"SCANMODE:b"
    I01,161,381,65,25,"MUTE:b"
    END
    May 2006
    i have this issue every time i use the slider and the label at the same time.
    cpu label works great only if used on its own.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ahhh.. ok, I'll check both at the same time now.. but it may be an issue of the code I'm using for CPU load.
    May 2006
    any news?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    cool skin, is this yours? Or is it avail somewhere here and i missed it.
    beer replenishment fund
    mp3car live search
    May 2006
    Quote Originally Posted by liquid_smoke
    thanks , it's mine... i'll post some screenshots in a new thread, bye!!!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've fixed it.
  1. Guino: Add to High CPU Load FAQ
    By d_sellers1 in forum Road Runner
    Last Post: 11-09-2006, 04:33 AM
  2. what could cause high cpu issue (hardware related i believe?)
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 05-31-2006, 08:08 AM
  3. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 02:16 AM
  4. Mobo, CPU and power rail
    By MatrixPC in forum General Hardware Discussion
    Last Post: 11-15-2004, 09:19 AM
  5. 500MHz & winxp /winamp2=100% CPU load !! ??
    By felix99 in forum General Hardware Discussion
    Last Post: 11-17-2002, 05:24 PM
