Results 1 to 3 of 3
Thread: The rr hangs with bluetooth gps
    Jul 2006
    I have a bluetooth gps and when all is turned on, all ok. But when i turn off the gps the rr freeze for 3 seconds every 15seconds. But the worse thing is that when i unplug the bluetooth usb its hangs more time about 10 seconds every 15sec.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That exclusively depends on the Bluetooth Drivers installed. Mine will hang for 3 seconds (searching for the device if it's not in range), but will not even lag a split second if I remove the Bluetooth dongle. There's not much I can do to fix this, I mean, it's the bluetooth drivers hanging for 3 seconds and not RR.. if you don't believe, open the GPS port in hyperterminal, then turn the GPS off (or move it away from working range) and do the same, you'll see it "freeze" for the same 3 seconds.
    Ride Runner RR's Myspace
    Jul 2006
    you are right, i clear the port in the rr config and it was everything ok.
  1. Will Bluetooth Delorme GPS work with Streetdeck?
    By fiveslo in forum StreetDeck
    Last Post: 06-15-2006, 07:56 AM
  2. Bluetooth GPS
    By MadStu in forum GPS
    Last Post: 06-07-2006, 05:35 AM
  3. iGuidance GPS Issue in RR
    By moeman_49 in forum GPS
    Last Post: 06-04-2006, 04:17 PM
  4. Replies: 3
    Last Post: 07-13-2005, 03:23 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
