Results 1 to 5 of 5
Thread: !Select+
    Aug 2005
    Athens,Greece
    !Select+
    Hello,
    I'm using the !SELECT+ method to add to my current playlist and be able to continue brownsing for more.
    I'm using the audio browser to reach to the directory I want to add and press the button with !SELECT+. RR instead of adding that directory and subdirs, it adds the whole music folder, ie the music directory declared in rr.ini.
    Am I using the command wrong or it is a bug from the software?
    Thank you in advance!
    George
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hi Gaslan,
    I think it a user thing ! If you want to add just one song, you need to use the "ADD1" command. If you want to add a selection, you need to be in the level below the selection you want to add, and then use "SELECT+".
    So, assuming you have your music structured like
    Genre
    -Artist
    --Album
    ---Track 1
    ---Track 2
    ---Track 3
    -Album 2
    ---Track 1
    ---Track 2
    ---Track 3
    This threw me for a while until I played with it for a bit, but if you want to add an album, you highlight a track, and use "SELECT+". This will add all the tracks at this level to the playlist.
    Hope this helps.
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Aug 2005
    Athens,Greece
    Quote Originally Posted by kpjuk View Post
    Hi Gaslan,
    Genre
    -Artist
    --Album
    ---Track 1
    ---Track 2
    ---Track 3
    -Album 2
    ---Track 1
    ---Track 2
    ---Track 3
    Hope this helps.
    KPJUK
    This certainly clarifies the things a bit for me! I've done some testing on this...
    Using your example Select, being in the browser and while Album 2 is highlighed (not in the dir), creates a playlist with Album 2 and subdirs.
    On the other hand !Select+ (using "!" because I want it to stay in the browser screen), using the case as above will add Album and Album 2 in the playlist. To get the same effect as SELECT, as you said, one must go into the Album 2 directory and use Select+.
    Is this the way it was intended to work?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    SELECT = add the current selected item: if folder, it loads the folder and adds all items in it, otherwise, just load the contents of current folder.
    SELECT+ = add all items in current folder.
    ADD1 = Add currently selected item only (file or folder).
    They all work in similar manner, the difference is how they handle where you are currently. the ! in front of the select just prevents it from exiting the browser screen.
    Ride Runner RR's Myspace
    Aug 2005
    Athens,Greece
    Quote Originally Posted by guino View Post
    That does it, I'll use !Select
    Thanks a million for the clarification Guino!!
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 02:37 PM
  2. Drop-down menus don't work? Read this!
    By gnomad in forum Announcements
    Last Post: 10-14-2005, 01:15 PM
  3. !Select command
    By Prem in forum RR Bug Tracker
    Last Post: 08-07-2005, 02:15 PM
  4. Window XP , bypass user account select screen
    By lookinco in forum Newbie
    Last Post: 09-05-2004, 03:31 PM
  5. Replies: 4
    Last Post: 01-06-2004, 07:00 AM
