Results 1 to 3 of 3
Thread: DELETEFILE dosnt work on .skin using MENU command
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    DELETEFILE plug other commands dont work on .skin using MENU command
    i have a playlist screen that shows you your playlistpath dir in a popup screen
    PLAYLIST.skin
    if i use the MENU command to load the screen, "DELETEFILE", "RENAMEFILE" do not work. I have the confirm.skin and i get the confirmation to delete the file or not, but it never actually deletes the file. When i choose to rename the file, i get the OSK but the file name is not present and it wont rename the file with any new text i give it.
    when i change the button that loads the PLAYLIST.skin from MENU to LOAD everything works fine.
    beer replenishment fund
    mp3car live search
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You need to execute those commands FROM the screen you want it to work with, so if you're making a menu for those commands, you should have "EXIT||DELETEFILE" and "EXIT||RENAMEFILE" for it to work.
    Ride Runner RR's Myspace
    Aug 2003
    Chicago
    AH, OK cool,
    ill keep that in mind in the future.
    I ended up just using a fullscreen .skin which worked out better cuz i found some usefull features to add with the extra space
    mp3car live search
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 02:02 PM
  2. Destinator: Map Monkey Menu command
    By MatrixPC in forum RR Skins
    Last Post: 05-07-2005, 11:53 AM
  3. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 01:53 PM
  4. EXTERNAL_XM_GPS_DVD_FM Command Line Options Do Not Work
    By frodobaggins in forum FP Bug Reports
    Last Post: 01-06-2005, 12:47 AM
  5. my menu button doesn't work on my skin
    By gambit32 in forum FrodoPlayer
    Last Post: 10-02-2004, 07:53 PM
