Sorry for two same threads, it was mistake
Hello! I just download latest version 06.09.2006 of RoadRunner and install it. When I tried to SCAN LOCAL in radio mode RoadRunner start scan ...87,5...87,6...87,7 MHz and scanning is stopped, now I can't scan and add radio stations automatically, I can only manually set frequency and add them to the list. As I can assume, RoadRunner start scan frequency and when first station is found it can not be added to the station list for some reason and scanning is stopped. I use Radiator to run radio. Before this version I used 07.10.2005 version of Road Runner with same plugins for Radiator and radio worked perfectly therefore the problem is not in Radiator.
Can anyone help me to resolve this problem? I might to install previous version of Road Runner and forget about this problem but I can't do it because there I can't make russian language be visible in playlist (russian is my native language). But in new version I can't to run radio without problems. I tried in new version replace radio plugin (radio.dll) from previous version and nothing happen but when I replace roadrunner.exe, radio going to scan stations without problem and add them to the list but I can't see russian language in playlist.
Can any help me? As I saw best assistant here is Guino, right? Guino, can you assume where is problem? Thank you in Advance!
...and excuse me for my english...
There has not been any modification change with Radiator support for probably a year. Same with language support. My best guess is that you've changed some setting in either Radiator or RR.
Ride Runner RR's Myspace
I noticed this also, tried to go back some version and it seems that the 06-03-06 version worked, but from 07-08-06 this has not worked...
I just replaced EXE, everything else was the same. Tried with WinTV as well as HQCT (i have both), same problem...
I honestly haven't changed anything with radio support, but I can install a wintv card and try it out.
I don't change anything in radiator, everything is same, scanning stations and adding them is not working. Please let me know where I can dowload 06-03-06 version? Thanks!
Get older versions here:
http://myspotontheweb.no-ip.org/inde.../page0008.html
Thanks for help but this page was Not Found. Do you have other link?
Sorry, try now, link was wrong...
Guino, this has to do with ONSONGSTART, did a debug on the old version and compared it to the new, and the new had a lot of ONSONGSTART events while searching, the old version had none of this...
2006-10-13 06:57:43: Enter Exec: False, radio_player.skin, , False
2006-10-13 06:57:43: Que Exec: True, radio_player.skin, "ONSONGSTART", False
2006-10-13 06:57:43: Executing: ONSONGSTART
2006-10-13 06:57:43: Leave Exec: False, radio_player.skin, ONSONGSTART, False
EDIT:
From Requests.txt in 7-8-06 version:
-Improved ONSONGSTART to be fired also with radio/sat/video changes
This definitely has something to do with this problem...
