Results 1 to 3 of 3
Thread: Refreshing customdl not working
    Mar 2006
    i have a customdl with the playlistpath.
    The list is on the audio player screen and has the SD definition:
    /, a Disp w h Path
    When i create or delete files there, the list does not reflect the changes.
    I've tried the following commands to refresh the list:
    and setting the _root.CUSTOMDL variable to "" and undefined.
    Nothing worked - it seems that the list is only loaded once..
    Please check, thanks!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is a limitation, the folder list only updates when/if you change the path. Since you're not changing it, it's not updating. You can make a refresh button easily by using "SETPATH;$PLAYLISTPATH$" and it will force the list to reload the specified path and update CUSTOMDL as well. Beware only the FIRST defined flash file in the screen receives the customdl.
    Ride Runner RR's Myspace
    Mar 2006
    it works, thanks!
  1. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  2. TS working... not working... work... not...
    By bulgogi777 in forum General Hardware Discussion
    Last Post: 01-11-2005, 10:25 AM
  3. AT&T Sierra Aircard 775 working on Mac OS X
    By rsanchez28 in forum Wireless Communications
    Last Post: 11-21-2004, 02:18 PM
  4. All built and working, just one last problem......
    By Matthew230 in forum Power Supplies
    Last Post: 10-18-2004, 05:02 PM
  5. Got GPS 16 working
    By tekknikal in forum General Hardware Discussion
    Last Post: 06-16-2002, 07:55 PM
