Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Help! RR 10-08-06 and OSK problem...
  1. #11
    Jul 2006
    Torino (Italy)
    Quote Originally Posted by guino View Post
    if you name your skin osk2.skin and use the "apposk2" command to load it, the old file (with Kxx lines) should work as it used to work with the "bug" in place.
    Yes, but with the "apposk2" is not so usefull as now.... Especially in search-mode...
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by sportmj80 View Post
    I don't understand what you mean... you can have up to 4 different application osks per skin -- osk.skin, osk2.skin, osk3.skin and osk4.skin -- so you should be able to use at least one to match the application in question for your own use.
    Ride Runner RR's Myspace
  3. #13
    Jul 2006
    Torino (Italy)
    Because my first skin of Destinator PN call the OSK with other size of embedding... If I use the apposk2 solution this is the result...
