Results 1 to 10 of 13
Thread: Help! RR 10-08-06 and OSK problem...
    Jul 2006
    Torino (Italy)
    Hi,
    I have a problem with the new RR. With my skin and destinator pn the OSK don't works. With the same OSK and old RR (like 10-31-05) it works correctly.
    I have also another problem with nero burning rom. When I try to rename my cd-label and call the OSK with "APPOSK", it type inverted... Eg: when I type "pippo" on the screen I see "oppip".
    Another problem is that, when RR close, It don't close all applications embedded, even if I have selected the option "close embedded apps on exit"
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    there have not been any changes in the way the OSK works.
    some programs do not work well with the OSK because of a focus issue.
    there have not been any changes with the close embbeded apps feature -- if it isn't working for you then you probably don't have it embedded right in first place.
    Ride Runner RR's Myspace
    Jul 2006
    Torino (Italy)
    Hi,
    thank you for your reply.
    Ok for the nero-osk and closing apps, these are secondary problems, but why for the destinator? The skin and the settings of RR are the same but with the old versions works and with the new not. I've tried with different PC and configurations but the result are the same...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I can't possibly remember all the changes that have been done within the past year. However, I'm interested to know if that OSK is from Destinator or from RR ? and if it works fine outside RR.
    Jul 2006
    Torino (Italy)
    Quote Originally Posted by guino View Post
    No, this is a simple OSK from RR, not external OSK.
    This is my skin code
    MEDIACAR Skin
    MEDIACAR GPS2 Skin
    /, K, x, y, w, h, Line, Ascii, Code, tooltip
    K32,7,411,68,62,003,113,081,"Q"
    K46,76,411,68,62,004,119,087,"W"
    K19,146,411,68,62,002,101,069,"E"
    K20,214,410,68,62,002,114,082,"R"
    K21,282,410,68,62,002,116,084,"T"
    K22,351,410,68,62,002,121,089,"Y"
    K23,420,411,68,62,002,117,085,"U"
    K24,489,410,68,62,002,105,073,"I"
    K25,558,410,68,62,002,111,079,"O"
    K26,626,411,68,62,002,112,080,"P"
    K28,420,348,68,62,007,055,055,"7"
    K29,489,348,68,62,007,056,056,"8"
    K30,557,348,68,62,007,057,057,"9"
    K17,7,471,68,62,002,097,065,"A"
    K33,76,471,68,62,003,115,083,"S"
    K34,145,471,68,62,003,100,068,"D"
    K35,214,471,68,62,003,102,070,"F"
    K36,283,471,68,62,003,103,071,"G"
    K37,351,471,68,62,003,104,072,"H"
    K38,420,471,68,62,003,106,074,"J"
    K39,489,471,68,62,003,107,075,"K"
    K40,557,470,68,62,003,108,076,"L"
    K42,214,348,68,62,008,052,052,"4"
    K43,282,348,68,62,008,053,053,"5"
    K44,351,348,68,62,008,054,054,"6"
    K18,7,533,68,62,002,122,090,"Z"
    K47,76,534,68,62,004,120,088,"X"
    K48,145,534,68,62,004,099,067,"C"
    K49,214,533,68,62,004,118,086,"V"
    K50,283,533,68,62,004,098,066,"B"
    K51,352,533,68,62,004,110,078,"N"
    K41,420,533,68,62,003,109,077,"M"
    K58,488,533,138,62,005,032,032,"SPACE"
    K55,6,348,70,62,009,049,049,"1"
    K56,76,348,70,62,009,050,050,"2"
    K57,145,348,68,62,009,051,051,"3"
    K59,626,348,68,62,010,048,048,"0"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,697,469,100,62,"GPS||SENDKEY;{BACKSPACE 2}{ESC}",
    B08,626,472,68,122,"SENDKEY;+{DEL}",
    B,697,532,100,62,"SENDKEY;%{F4}",
    B,697,409,100,62,"SENDKEY;{UP}",
    B,697,348,100,62,"SENDKEY;{DOWN}",
    /, A, x, y, w, h, color;RGB
    A01,4,0,792,340,000
    /, C, x, y, w, h
    C01,4,0,792,340
    END
    This skin will loaded by this button:
    "LOAD;GPS_OSK.SKIN||RUN;C:\Mediacar\DestinatorPN\D estinator.exe;Destinator||SENDKEY;{F2}"
    guino's Avatar
    Nov 2004
    Toronto, Canada
    do the Bxx,xxx buttons on the bottom work ?
    Jul 2006
    Torino (Italy)
    Hi,
    yes these buttons works correctly
    The Kxx don't work
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can change the Kxx lines into Bxx lines like this:
    to:
    B32,7,411,68,62,"SENDKEY;Q"
    and it should have the same effect. The thing is that previous versions of RR would inavertly send the key to any embbeded app, when in fact it should only do so using the APPOSK (not the case here). This was fixed, therefore the "bug" you were taking advantage of was gone.
    Jul 2006
    Torino (Italy)
    to:
    Hi,
    I have tried and works, but it worked better with the old “bug”. Sometimes it gives problems that the text don't continue letter after letter but it is overlapped, that instead with the Kxx did not happen.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    if you name your skin osk2.skin and use the "apposk2" command to load it, the old file (with Kxx lines) should work as it used to work with the "bug" in place.
